2ndGenGuy
The only weird issue I ran into when putting the struts back together was on the rears. The springs were so short that when the shocks were fully extended, the spring wouldn't be seated in the perches. It wasn't drastic like my springs were going to pop out, but it was enough to concern me. I figured if I'm autocrossing, and I get the car up on 3 wheels (which has happened), or if I hit an unexpected pothole and the shock drops clear out, it could be bad news.
To solve this, I simply cut the collar that goes between the strut rod at the top and the bushings. I only took about 1/8 inch at the top off, but it tightened the perches down on the springs tighter. It also tightened the cap up on the bushings much more securely. I felt much better with this assembly than without those cut off.
Here you can see how they looked originally, vs how they look after cutting. There's not a lot cut off, but it made all the difference.
