My 89 Lxi is over heating,the radiator is cold and so is the top hose but the bottom hose is warm, also I've got good heat inside and the fan is working.There was good pressure when I took off the radiator cap.
any ideas?
Thanks,jim
any ideas?
Thanks,jim
thermostat
Originally Posted by reanimator420
yeah i paid 10.88 for mine from honda....and it fixed my overheating prob.
well what about underheating. my car never warms up... my car never has heat unless it's summer... think the thermostat is clogged open????
I've moved on to bigger and better things. 94 integra Gsr Sedan is my new ride. And theres big things coming for it.
I guess i'll have to try the thermostat,it's colderthan a witches tit right now.
Thanks guys
for a quickie you can take the hose off and punch it with a long screwdriver should get some flow to the radiator thenOriginally Posted by NoGeezsGap
Would be easier to just replace the thermostat then try to get it to work.Originally Posted by njpeter
sure assuming that the housing comes off without any problem, I've run into a problem with stubborn bolts, and penetrant can take a few hours to loosen em up, you don't want to have a bolt snap in the middle of winter, specially if you don't have a garage to work in. I've used the srewdriver thru the thermostat a few times in a pinch to cure an overheating car when it wasn't practical to replace the thermostat ( like on the side of the interstate during a blizzard for example)
I've done that before, I had a oldsmobile and I was on a long trip, car started to overheat in the middle of nowhere.Originally Posted by njpeter
You do what have to do when you need to
if your car doesn't get hot your thermostat stuck open. replace it and you should be fine.
if your car overheats. the thermostat stuck closed (cheap brands do that). replace thermostat and it should be fixed.
The best thermostat for our cars are OEM honda from a dealer. it works better than some aftermarket thermostats.
oem for honda = excellent. but i've got a ac delco thermostat sitting around...
what do you {experienced} guys think about ac delco... what would you choose as a 2nd source to oem....?
A/C Delco is a good second choice. I use some of them from the parts house.
