Results 1 to 8 of 8
Thread: Cruise Control
    Jan 2007
    89 Honda Accord EX-i
    Hamilton, On
    Cruise Control
    One day I was driving home from work and my cruise didn't work. I have checked all fuses and vacuum lines and there are no problems. The main switch seems to be working since the light is on but it will not set. The light in the dashboard doesn't come on either.
    Any suggestions on what this might be?
    Re: Cruise Control
    Check the connector on the cruise control actuator. If it seems to be ok, then possible one of the wires broke off on the slip ring on the combination switch. You can check if you just pull the steering column cover(upper/lower). The set of wires that are for the cruise control are located on the bottom of the column, and they are very close to the steering wheel. You should be able to see 3 of them, with a 4th single wire connected with a connector.
    race12001's Avatar
    Sanford NC
    Re: Cruise Control
    yea the only other thing to do is to pull the front of the wheel off and look and see if anything broke in there if every thing looks fine you might want to head to the jy and look for a new one
    Dec. 05-Dec. 06
    shepherd79's Avatar
    Falling Waters, WV USA
    Re: Cruise Control
    Quote Originally Posted by race12001
    why would he pull the wheels off? there is nothing there for cruise control?
    check the buttons on the steering wheel and check the control box. it could be the box.
    I had to replace one on my wife's 01 civic.
    Re: Cruise Control
    Quote Originally Posted by shepherd79
    well i had to pull my well and i used an ohm meter to see if my buttons worked...it did so idk wut gave up....il just pull the part out.
    race12001's Avatar
    Sanford NC
    Re: Cruise Control
    yea i didnt say pull the wheel i said pull the front of the wheel so he can look at the connector
    Dec. 05-Dec. 06
    shepherd79's Avatar
    Re: Cruise Control
    oh you mean steering wheel.
    Re: Cruise Control
    There are vacuum lines going to the controler too, if there was a vacuum problem I do not think it would work either.
  1. cruise control
    By ripcord in forum Carburetor Tech
    Last Post: 06-11-2011, 09:36 AM
  2. Cruise control?
    By Nio in forum 3geez Accords
    Last Post: 01-15-2010, 09:53 PM
  3. Cruise Control!!!
    By kaltenacht in forum 3geez Accords
    Last Post: 05-24-2005, 01:51 PM
  4. cruise control?
    By jaiden in forum 3geez Accords
    Last Post: 03-08-2005, 01:30 PM
  5. Cruise control......................
    By bigpoppa88 in forum 3geez Accords
    Last Post: 08-10-2002, 04:53 PM
