Results 1 to 9 of 9
Thread: will anything from another series motor swap to an a20a3?
    DX User raven100112's Avatar
    Feb 2007
    1989 honda accord lxi
    i need to know if anything will swap over from other motors to the a20a3.
    Re: will anything from another series motor swap to an a20a3?
    like performance stuff
    miata ARP head bolts
    eagle teg H beam rods
    anything else you will have to search or try it out your self.
    shepherd79's Avatar
    Falling Waters, WV USA
    it all depends what kind parts are you trying to use.
    tell us what kind parts you are think of using from another engine?
    and what engine?
    Feb 2007
    i was thinking the intake man off a f22
    shepherd79's Avatar
    Quote Originally Posted by raven100112
    no it will not fit.
    you can modify B16 b18 manifold to fit. just have to drill a few wholes, but than you will have to figure out what to do with EGR valve and other shit. If you unplug them you will set off ECU and your car will run like crap.
    10/Honda/Ridgeline
    NJ
    Fucking A Man. Wtf is this damn Newbie world take over or something. Every damn guy asking same damn questions.
    Well to answer your question, here are the things that will fit from other cars that are considered to be performance parts from other engines.
    Fuel Injectors
    Intake Manifold
    Connecting Rods
    Head Bolts
    Throttle body
    Modified Piston (has to be the same fit as the rods)
    Jun 2001
    Boston MA
    it takes more engery. banwith and actually more time searching by telling someone to search theny typing a simple answer. i was searching for some info on pistons the other day and every thread that came up 6 assholes told the newb to search. now it suck when you are actully trying to bring up info using the search and you come across replys saying search. this shit needs to stop.
    if you plan on using ls rods you will need to notch the block. in the project research section alot of people are working on odb1 conversion using modded 93 accord distributors. there isend too much direct fit stull, but alot more stuff will work with simple mods. look up alot of Lengend_master thread, hes usually pretty good at custom modifications
    S.Q.U.A.D. Engineering
    www.squadengineering.com
    Quote Originally Posted by SQ is the SQUAD
    look up alot of Lengend_master thread, hes usually pretty good at rigging things up
    Not rigging, "custom modification" .
    Jun 2001
    Boston MA
    youre the man!
  1. Engine Swap (A20A3 to A20A3)
    By mike_fx_u in forum 3geez Accords
    Last Post: 06-02-2018, 07:15 PM
  2. 87 accord a20a3 motor trans swap
    By farmboy963 in forum Performance
    Last Post: 06-02-2009, 10:46 PM
  3. B series motor swap
    By Magny in forum Performance
    Last Post: 01-02-2006, 01:52 PM
  4. a20a3 motor swap???
    By od2681 in forum General Engine Swaps
    Last Post: 04-09-2003, 05:52 PM
  5. Fixing My Accord with swap 86k a20a3 motor
    By Tref_LXI in forum 3geez Accords
    Last Post: 03-11-2003, 10:17 AM
