Results 1 to 7 of 7
Thread: Air Conditioning fuse
    LXi User Steve_Si's Avatar
    1986 Honda Accord 2.0Si
    Christchurch, New Zealand
    Can someone tell me the general location of the air conditioning fuse? All the fuses in my car are labeled in Japanese so it's kinda hard to tell. The air never gets cold and the radiator fans never start.
    Ah the joy of having an old car, I can actually try and fix it myself
    Re: Air Conditioning fuse
    why not try to check all the fuses. sometimes you can find more than one burned out.
    May 2003
    88 Accord LX 88 Accord LXi
    It might be low on freon. There is a pressure switch near the receiver dryer. If you unplug the connector and jumper out the 2 contacts, turn the key on and see if the fans come on.
    If the fans come on then the freon is low.
    Actually it seems the fans never come on no matter what, same with the compressor. First up I better get them working to control the engine temperature.
    I've downloaded the shop manual for the USDM models which gives instructions on how to troubleshoot it all, hopefully my car is similar enough to the USDM models.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Test your fan motors, it's easy.
    https://www.3geez.com/forum/showthread.php?t=57926 Post #17
    The fans themselves work, as far as I can tell my thermosensor is faulty. When I unplug it and short the pins both fans come on all the time. A new one is arriving in a couple of days. Once that problem is sorted I'll get to work on the air conditioning.
    New thermosensor got the fans going again Can't get on to the air conditioning until i've got the heater fan blowing properly /looks at OD
  1. Where is the radio fuse on the fuse rack??
    By Stoff81 in forum Interior & Exterior Care
    Last Post: 10-09-2010, 01:59 PM
  2. Air Conditioning
    By Timaculent in forum Classic Honda Community Chat
    Last Post: 11-10-2008, 08:43 AM
  3. Air Conditioning!
    Last Post: 08-07-2006, 01:38 PM
  4. ? about air conditioning?
    By 88fasthatch in forum Classic Honda Community Chat
    Last Post: 06-01-2004, 08:34 AM
  5. air conditioning
    By biggybaz in forum 3geez Accords
    Last Post: 04-13-2004, 06:49 AM
