Results 1 to 5 of 5
Thread: Is P/S Pump Killing A/C Compressor?
    LX User bushbean's Avatar
    The A/C started to blow not as cold just when the P/S Pump started to leak its fluid got all over the A/C compressor. Coincidence? or is the P/S Pump leak killing the A/C compressor by soaking it with P/S fluid?
    Re: Is P/S Pump Killing A/C Compressor?
    i don't think so.
    it is probably huge coincidence.
    AC is a sealed unit. you are probably just getting low on freon.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    When my power steering pump went the AC clutch became soaked with oil and started slipping. Fix it and degrease the clutch. I left mine for a long time and the rubber in the clutch deteriorated. If you leave this your clutch will eventually need to be replaced or at least be shimmed.
    Blkblurr's Avatar
    Dayton, Ohio
    Quote Originally Posted by LX-incredible
    I agree. The clutch will not last long if it's covered with oil.
    To clarify:
    The PS pump has probably been leaky for a long time, probably long before the A/C's degrade in performance. I didn't bother to check anything until my A/c's performace started to degrade, and that's when I saw the A/C compressor covered with PS fluid.
    I don't think putting the PS pump right above the AC was a very smart move by Honda.
  1. Killing Honda?
    By 86ccord in forum Classic Honda Community Chat
    Last Post: 03-09-2008, 06:45 AM
  2. What's killing my battery?
    By spacecapsule1 in forum 3geez Accords
    Last Post: 09-28-2007, 05:14 PM
  3. help....carb is killing me!!
    By psdrummin in forum Carburetor Tech
    Last Post: 12-13-2006, 10:49 PM
  4. this accord is killing me
    By wallacefan in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-28-2006, 02:41 AM
