Results 1 to 5 of 5
Thread: my steering rack?
    LXi User Crazybird's Avatar
    89 4 door accord lx
    winnipeg
    my steering rack?
    ok so i got to park my beast int he garage and when i left everything seemed fine. but lately the steering has been a little choppy
    so i come home today and my dad was like man go check ur oil, ur car was spitting all over the place
    so i check the oil and discover that my power steering oil is down to the low mark
    so i thought well thats probably why my car was steering a little funny. but then my dad tells me that if its really cold and i turn the wheel when not moving it coulda buggerd up my rack..... and i kinda spun my tires and turned the other day and i noticed sumthing funny right after it
    so any advice as to whats wrong or will the oil be the answer since i have not driven my car yet since putting in the oil
    DX User 1990DSM's Avatar
    Feb 2007
    1989 EX-I, 1982 SUPRA, 1989 Toyota Cressida, 1997 CAVALIER RS
    Chatham, Ontario
    Re: my steering rack?
    Your power steering pressure line probably has a hole in it. Every Accord I've owned had that problem.
    89 4 door accord lx
    winnipeg
    which line is that? and im guessing id have to buy a new line if it does have a hole right?
    LXi User 87lxiaccord's Avatar
    1987 honda accord
    st.pete
    yeah i have the same problem whenever you turn the wheel all the way it'll spit fluid everywhere, But in my car it only spits it out if the fluid is on the high mark if you leave it a little low it doesn't do it anymore. I'll just drive like that until i figure out if i need to replace the whole rack or just a seal or something
    <3 sohc
    Blkblurr's Avatar
    Dayton, Ohio
    It's most likely the one that goes in between the radiator and the valve conver. The leak should be easy to find. BTW, your not going to hurt your rack by turning the steering wheel when it's cold. About the only way to hurt the rack is to run the car against a curb or try turining the steering wheel hard when the wheels are against something that doesn't move. If your rack is already bad (leaking) you could make it worse by doing what your Dad said.
  1. Steering rack removal
    By King Peetis in forum 3geez Accords
    Last Post: 05-09-2012, 02:07 PM
  2. Steering rack boot
    By kentwat in forum 3geez Accords
    Last Post: 03-02-2010, 08:07 AM
  3. Steering Rack - bad?
    By vongiese in forum 3geez Accords
    Last Post: 02-03-2006, 01:59 PM
  4. steering rack
    By 89se-i in forum 3geez Accords
    Last Post: 12-17-2005, 06:55 PM
  5. steering rack
    By sxegirl in forum 3geez Accords
    Last Post: 07-11-2002, 06:36 PM
