Results 1 to 13 of 13
Thread: Carburetor Enhancer
    Carburetor Enhancer
    just browse on the net and found this.......
    Full article>>>>http://www.steamengine.com.au/ic/eng...our/index.html
    did anyone here know about it??is this thing works??if yes...i'm gonna try to DIY it...
    Hope to hear any feedback from ur guys...
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Re: Carburetor Enhancer
    hehe just looking at the picture makes me wonder how much the vacuum is raising the fuel level in the float bowl if it's sealed.
    I'll read the link later. But thanks for posting it.
    EDIT: hrm actually the rate at which the fuel could be refilled would increase, but not nessescarily the level itself... anywho back to my movie.
    ya let us know how it turns out i dident read the article but if u could tell us what its to achieve that would be awesome
    A20A1's Avatar
    Sep 2001
    OMG I didn't even know theses existed... I want one baaaaaaaaaaad!
    http://www.mossmotors.com/Shop/ViewP...eIndexID=31629
    at least we know they are not sealing off the float chamber.
    I was reading the paragraph under "SIZE"
    I saw they mentioned eagle research so I looked them up in google as well.
    http://www.eagle-research.com/fuelsav/carbenh.html
    I had a simmilar mod which I was going to try venturi vacuum, using manifold vacuum I was worried there would be a vacuum leak...
    here was the setup:
    I modified the top hat quite a bit.
    interesting stuff, site glass for combustion chamber.. hmmm
    I use the white mouse exhaust analyzer set. Uses replacable white mice, place mouse at tailpipe, if the mouse turns red, too lean, mouse bursts into flames, way too lean...mouse turns black too rich, mouse runs around in circles three times and ducts inside the tailpipe, just right.
    Vanilla Sky's Avatar
    1999 Penalty Box
    it looks like our stock carb rats nest already employs a similar circuit. see hoses 14 and 11.
    A20A1's Avatar
    Sep 2001
    Quote Originally Posted by roodoo2
    Are ya trying to say the product is not worth it?
    A20A1's Avatar
    Sep 2001
    Quote Originally Posted by Vanilla Sky
    14 is the Power valve Which is a sealed system aside from a tiny bleed hole.
    11 does go to venturi vacuum, but it ties into the EGR Control Valve
    None of them vent the float bowl in the stock setup.
    Also don't hook vacuum to the Air Jet Controller ports at the back of the carb or you risk syphoning out fuel.
    cygnus x-1's Avatar
    Chicago area
    Looks to me like just a way to draw off carb bowl vapors and mix them in with the air/fuel charge. Basically the same thing that the charcoal system does, without the temporary storage that the canister provides.
    C|
    Quote Originally Posted by A20A1
    Oh not at all, the product is pretty darn interesting
    Honestly, I was bringing forth a little humor on the subject. There are plenty of ways to detect correct mixture settings. Even so there seems to be a continuing variance on four cylinders with carbs. You can have it perfect one day and then the next day it is slightley off, so yes I empathize with efforts towards devopment of any device that can help us.
    It is usually pretty obvoius when rich conditions are present but when lean out conditions exist, that is what warrents serious attention. Exhaust tempurature guage is a favored device IMO.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Very cool, I had no idea that these existed. $75.95 though, seems you could spend that on other means of checking combustion.
    CARDONE SUCKS.
    2ndGenGuy
    Guest
    So how does vacuum in the float bowl prevent flooding and increase fuel efficency?
    A20A1's Avatar
    Sep 2001
    No his beef on flooding was nothing to do with this mod... flooding was caused by bad needle seats... and he knows it.
    I dunno about fuel efficiency... I've still only skimmed his page.
  1. 87' carburetor rebuild...
    By zack_attack2010 in forum Carburetor Tech
    Last Post: 10-01-2017, 10:33 AM
  2. Carburetor adjustment
    By Rippen Griffin in forum 1geez Tech & Performance
    Last Post: 07-25-2010, 07:47 PM
  3. Carburetor swaps
    By bluesky6 in forum 2geez Tech & Performance
    Last Post: 03-21-2010, 07:46 PM
  4. carburetor
    By badbobb in forum 2geez Accords
    Last Post: 04-01-2009, 03:45 PM
  5. Carburetor idle
    By russiankid in forum 3geez Accords
    Last Post: 04-14-2008, 07:50 PM
