Here is a pic of a 86-89 accord
now here is a pic of the 92-95 integra alternator it looks just like the accords and its a 90 amp to and it has the same plug as the accord.
Awesome.
not that you have to resize them but...smaller pics are nicer though when you try to compare two or more things because you can fit them on the screen at the same time instead of having to scroll up or down or side to side. The 300 X 200 pixl;e one is a good size, you can line them up in collumns that way
Bump
Cool, looks like it would fit. I checked some online parts stores the 90 amp alternators only went on 94 and up tegs. The earlier models had the 65, like ours. http://catalog.autohausaz.com/autoha...r=1994&make=AC
i am going to buy one this weekend and see how it fits.
Y not use the legend alt? its like 120 or 140 amps. I got one in mine.![]()
has anyone thought to see if the guts on the teg alternator would fit in the accord case? it' perfectly possible the teg alternator is exactly the same with a high output stator and different regulator. I'm going to try this conversion myself too,since I have to replace my alternator anyways.
Here is some pic's of the Legend 91-95 110amp
I pulled both the Accord and Integra alternators off the shelf and the only difference I can see on the ones we have here is the pulleys.
The accord has a 5 groove and the integra has a 4 groove
dont the integra differentiate form 90-93 and 95-01? maybe just the odb1 altinators had more power, i dunno 92-95 isent rerally a generation for the integra, its for the civic. i dunno if it really matters
S.Q.U.A.D. Engineering
www.squadengineering.com
Originally Posted by picopop
i want a job like yours pico even tho you hate it....it sound like fun...you are my HERO! :superman picopop simily:
That's what I'm thinking. I don't have Hollander at my house but I'm pretty sure you have Civic on the brain.Originally Posted by SQ is the SQUAD
OT: That first picture is from my main eBay competitor's listing.![]()
Honda Parts Connection -- http://www.acurahondaparts.com
D Series Army Dishonorable Discharge
BT Defector
Any one try this yet?
BT Defector
I checked with my rebuilder on this one and he say's that that wiring in the plug is different than whats on the accord alternator.
The plug looks the same but the wires are for different connections...
uh oh..........
hey pico can you check the legend alternator?
here is a so-so write up click me
I checked the illustrated guide at work and the plug wiring is the same, It's just the mounting points for the adjuster and maybe the belt thats needs to be modifiedOriginally Posted by MessyHonda
I get my legend alternator tomorrow then i will test fit it on my b20a witch has the same alternator mounting as the a20a.I will take some pics.
those big alternators steals all the horsiesWell I suppose that's debateable but is it really needed..
out of curiosity, since the higher output alternators put out more power(obviously), wouldnt it overpower the entire charging system and what it was made to handle?
Originally Posted by newaccorddriver
you upgrade your grounds.
the valve cover to chassis and tranny ground? what other ones do i need to do?Originally Posted by MessyHonda
