You should get a motor from the junkyard and rebuild it and have some head work done also. You have most of the bolt-ons other then a cam gear, blaster coil, ect. Other then that stuff you might want to look into suspension mods like lower it a little, strut bars, tie bars, SE-i rear discs, better rotors and pads (If you make your car go faster you also want it to slow faster or things might get ugly). And as far as looks go maybe look into window visors, JDM corner lights, tinted tail lights, ect. Your off to a good start, im interested to see what it looks like a few months from now. Also you can do some things to help make the engine bay a little cleaner and easier to work on and the car a little lighter if you remove things like A/C, cruise control and P/S, it all depends on if you use the stuff or not, if you use it dont remove it but if you dont then why not. I never used my A/C or cruise control so i just removed it, and im going to remove the P/S when i put the new motor in.
