Results 1 to 5 of 5
Thread: Power antenna v. manual antenna masts
    SEi User
    81 HB LX, 84 HB S, 89 LX-i Coupe
    Indianapolis, IN
    Okay, are they the same part or will a manual mast work in a power application?? I tend to say "NO", that they are different because of the teeth on the power one, where the manual one could just slide with no teeth needed. The motor itself is fine. Is there an aftermarket mast for the power antenna (89 lx-i) that anyone knows of THAT WORKS!! Not one that sorta fits or is made for like every car out there with an A pillar antenna and you "mod" it with scissors, shims, and screws to make it "fit". A match, if you will. I know the rear mounted Honda power antennas have decent aftermarket masts and even motors that fit well. Any sites or name brands would be tight. $112 is just too damn much for the mast; about $85 wholesale.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    So you want to replace a power one with a manual or you want to get a power one?
    SEi User
    Indianapolis, IN
    i have a power one with a bad mast. I want to replace the mast itself, but save $$$$.
    10/Honda/Ridgeline
    NJ
    i would say get an aftermarket pwr antenna that goes on the trunk of ur car (to the side of the trunk) and wire up ur antenna wire thru either the headliner or thru under the carpet. But if u wanna keep the stock look, i would ask u to look at how the whole teeth inside the motor is and find something similar to it and also one thing to watch out is the thickness of it. and the length. Or go to the junk yard, have fun taking off the dash, and check out if they got a working antenna mast. good luck bro.
    shepherd79's Avatar
    Falling Waters, WV USA
    yeah get aftermarket one, because it is a pain in the ass to work on our antennas. i tried one time and i had to stop after 2 hours of nothing. it is impossible to work on it, unless you have a dash out.
  1. 89 Se-I Power Antenna
    By truble64 in forum Interior & Exterior Care
    Last Post: 12-09-2008, 03:56 PM
  2. power antenna
    By import racer in forum 3geez Accords
    Last Post: 11-12-2007, 11:52 AM
  3. Antenna! Power v. Manual... How to?
    By offthahook in forum 2geez Accords
    Last Post: 11-13-2006, 11:10 AM
  4. Power antenna
    By brianc85 in forum 3geez Accords
    Last Post: 06-25-2002, 12:54 PM
  5. power antenna !??
    By ACCORD EX in forum 3geez Accords
    Last Post: 06-23-2002, 02:01 PM
