Results 1 to 25 of 38
Thread: tranny removal help please!!
    i searched and found this thread https://www.3geez.com/forum/showthrea...tranny+removal
    and my problem is pretty much exactly the same as his:
    I've got all the wires/hoses/bolts/axles out of the auto, the whole transmission is about an inch off of the engine but still haning on to somthing, I have it pretty much butt up against the sidewall but it refuses to fall down. Any help would be appreciated. I need to get this done as soon as possible, I do have a car I can borrow for work but would prefer not to. Thanx.
    and a further post down it says:
    Did you Disconnect the torque conveter from the drive plate???? That will keep ypu from being able to lower the tranny down. You'll be able to go back but not down
    and that fixed his problem, but im having the exact same problem except ive already unbolted the torque converter from the drive plate.. any ideas why this would be?
    Re: tranny removal help please!!
    OD are you sure you got all the bolts off of the plate. there is a total of 8 holding it on?
    you may have to use a pry bar to help move it, when we did mine it was a little hard to get apart.
    yeah i'll try that
    still stuck
    damn its all the way up against the wall and it's about a inch lower now but it wont drop anymore even if i wiggle it around etc
    did u disconnect the negative battery cable as funny as it sounds the first time i took my tranny off we forgot and it just hung there buy that dinky little cable
    yup
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Spin the torque converter, while pushing it into the tranny. When you took it apart you probably pulled it out of the tranny a bit. It will need to be held up while your are doing this and it needs to go in straight. I have had the same problem.
    CARDONE SUCKS.
    ok lemme try that
    the tranny is cleared from the driveplate so its nothing in there stopping it from dropping down i cant see what else is stopping it
    Sep 2006
    Tucson, AZ
    Is the center piece of the TC pulled out of the flywheel?
    CARDONE SUCKS.
    yup, i can see its cleared the fly wheel
    Sep 2006
    Tucson, AZ
    And you got that "8" shaped mount.
    CARDONE SUCKS.
    which one is that? o.O the dog bone??
    Sep 2006
    Tucson, AZ
    No, it is the one that connects the tranny to the passenger frame. Oh wait, sorry, I am being stupid. I forgot that it is a B20.
    CARDONE SUCKS.
    oh
    Sep 2006
    Tucson, AZ
    I am tring to find more info. Do you have any pictures?
    CARDONE SUCKS.
    nah no pics sorry
    well the pics i do have wont be much helpfull i dont think
    Sep 2006
    Tucson, AZ
    The axles are pulled out, right? If not the halfshaft support could be holding it.
    CARDONE SUCKS.
    yup axles & halfshaft are out
    Sep 2006
    Tucson, AZ
    Okay, are the power steering hoses and speedo cable removed from the speed sensor? Is the throttle linkage removed? This may help: http://www.thehondapartsstore.com/he...istallcomp.jsp I am looking it over now.
    CARDONE SUCKS.
    yup all thats removed, and that link dont work for me
    Sep 2006
    Tucson, AZ
    I can't find any good pictures. Try rocking it and watch what moves with it. On mine part of engine wiring harness attaches to it near the top. The tie rod looks like it would be in the way, and the center beam might need to be removed. Sorry, this probably doesn't help. Someone on here has to have done this, so good luck.
    CARDONE SUCKS.
  1. Tranny Removal/Clutch Change Woes
    By 86lx-i in forum 3geez Accords
    Last Post: 02-12-2009, 07:26 PM
  2. tranny shift problem possably bad tranny
    By xxxfrankensteinxxx in forum 3geez Accords
    Last Post: 05-05-2008, 08:50 PM
  3. Need help ASAP with auto tranny removal.
    By HostileJava in forum 3geez Accords
    Last Post: 07-06-2004, 05:14 AM
  4. does all honda tranny use motor oil in the manual tranny?
    By 1988_5spd_lxi in forum 3geez Accords
    Last Post: 01-08-2004, 10:29 PM
  5. Replies: 3
    Last Post: 06-17-2003, 04:54 PM
