Results 1 to 13 of 13
Thread: Valve adjustment help?!!
    Feb 2001
    '87 Accord LX
    Renton, Washington
    I've adjusted my valves twice now, and they're still ticking a little. I think it is because I was turing the camshaft pully instead of the crankshaft pully. Anyway, what do you guys with stock cams normally set the spacing to? Your help will be greatly appreciated.
    '85 lude
    houston
    i do mine at 8 and 10.
    it doesnt matter turning the cam or crank.
    and there is always gonna be some ticking. all honda's are like that.
    Nov 2000
    If you make them tight enough to eliminate the ticking completely they will be too tight and you will end up burning a valve.
    Feb 2001
    '87 Accord LX
    Renton, Washington
    mine has an annoying amount of ticking that it didn't have before I adjusted the valves the first time, that's all. I thought I was doing it to make my car quieter but it only got louder.
    10/Honda/Ridgeline
    NJ
    usually, those kinda stuff are better left to a mechanic, but if u can do it and know how to, then do it. U dont wanna mess with the internals ulnless ur 100% sure of it. The good thing about my mechanic is that he is a family mechanic and he usually has be right beside him, asking me to get my hands oily and work around the car with him. He is a kinda guy who does not want anything to be a trade secret. Man...... ppl like that are sooo hard to find these days.
    Feb 2001
    '87 Accord LX
    Renton, Washington
    Thats true. You're very lucky to have a pro to help you. I fixed it tonight and there's no more blatant, annoying ticking. I adjusted intake to 7 and exhaust to 10. Thanks for your help.
    1986 Accord LX
    Ny
    10 for exhaust and 6 for intake
    Aww. Its Not Pink! How hard would it be to paint this sucker?
    The book says:
    0.010" INTAKE
    0.012" EXHAUST
    With Camregrind Mine are @
    0.008" INTAKE
    0.010" EXHAUST
    I would be careful when setting the gaps to small, you could get slapping of the valves which sounds simmilar to tapping.
    But tapping does less damage to the valvetrain.
    Feb 2001
    '87 Accord LX
    Renton, Washington
    my book says 5-7 intake, 10-12 exhaust, so it sounds like i'm within the limits.
    88 LX-i
    ellisville MO.
    first off you MUST turn the CRANKSHAFT PULLY, secondly the valve that you're adjusting MUST be on BASE CIRCLE. if your car is a manual, you can leave it in gear and just push it backwards(5th gear works the best).
    my cam (213/[email protected] 0.431lft) is adjusted to 0.008in on all valves, no ticks, nice and smoooooth. if the the valves are to tight, then there will be no slack to absorb the valve train inertia and your valves will float. if the valves are to loose, then the valve train will destroy its self.
    call your honda dealer to get the proper specs on the valves, but your ear should br good enough
    I’ll kill you with experience
    Feb 2001
    '87 Accord LX
    Renton, Washington
    strange, the book says nothing about all of that! Anyway, it doesn't tick anymore, and it doesn't slap and 10 exhaust and 7 intake are the max intake and min exhaust in my chiltons so i think i'm ok.
    Nov 2000
    I used to use 6 and 11 since the manual indicated 5-7 and 10-12. I recently bought a set of "Go-No-Go" feeler gauges and it just so happens that 5-7 and 10-12 are two of the sizes. It is hard to explain how these things work, but they make the adjusting a lot easier than with the regular one-size feeler gauges. A trusted Honda mechanic recommended them to me.
    I got mine at Auto Zone. They were right next to the regular feelers and were about $6.
    Feb 2001
    '87 Accord LX
    Renton, Washington
    I might have to look into that! Thanks man
  1. Valve adjustment
    By valerit1 in forum 3geez Accords
    Last Post: 06-18-2025, 08:26 PM
  2. b20a valve lash adjustment!!!!!
    By 3gmodifier in forum JDM B18A / B20A Swap Tech
    Last Post: 01-20-2009, 06:19 PM
  3. valve adjustment w/ new head
    By 88accordSF in forum 3geez Accords
    Last Post: 08-25-2007, 03:59 PM
  4. Got Problems after Valve Adjustment
    By jigga225 in forum 3geez Accords
    Last Post: 12-30-2003, 12:02 PM
  5. valve adjustment question
    By 2old_honda in forum 3geez Accords
    Last Post: 12-17-2002, 12:26 AM
