Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: Need help with suspension and cv clicks
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Re: Need help with suspension and cv clicks
    lol @ h&r springs being too stiff. Those are the softest lowering springs you can get. Rear rates are maybe 20% stiffer than stock, iirc (of note, ride quality is mostly determined by how stiff the rear is).
    You have a lot lower profile tires with 13, which means less sidewall and compliance, which contributes to the rougher ride. Not much you can do about it, short of putting your stock springs back on.
    Alex
    Well I still think it was your suspension bottoming out.Not trying to beat a dead horse or anything. The HR springs don’t sound to much stiffer than the numbers I have for our cars.
    TRW Coil Spring Front
    Part Number: CC248 86-89 Accord/88-89 Prelude
    INSIDE DIA.= 2.5 in.:
    BAR DIA.= 0.5 in.:
    FREE HEIGHT= 12.88 in.:
    SPRING RATE= 278.5 Lbs./In.:
    LOAD= 524 Lbs.:
    LOAD HEIGHT= 11 in.:
    END 1= SQUARE:
    END 2= TANGENT
    TRW Coil Spring REAR
    Part Number: CC221 86-89
    INSIDE DIA.= 3.062 in.:
    BAR DIA.= 0.485 in.:
    FREE HEIGHT= 13.27 in.:
    SPRING RATE= 170 Lbs./In.:
    LOAD= 387 Lbs.:
    END 1= SQUARE:
    END 2= TANGENTI
    The strut numbers say we have about 4 inch travel in the front and 6 in the rear stock so and lowering is going to cut into that then weight added to the rear.
    88 Lxi accord frnt Strut
    Item#: NS 71829 (NAPA
    Body Length:11.000"
    Compressed Length:11.125"
    Extended length:15.250"
    Travel Length:4.125"
    Rod Nut #:Included in parts pack
    Parts Pack(s) #:P906
    Item#: RR 201227 Rear Strut NAPA
    Attributes:
    Body Length:15.375"
    Compressed Length:15.500"
    Extended length:22.125"
    Travel Length:6.625"
    Upper Mtg. Nut Number:Included in parts pack
    Parts Pack(s) #:P878
    Still doesn’t explain why the Blues are working and the revalved Bilsteins don’t. But im wondering more if there possibly blown.
    Wp
    Banned
    May 2007
    Quote Originally Posted by 86AccordLxi
    Alex
    I thought NEUSPEEED springs were the softest available, at least according to the FAQ.
    Banned
    May 2007
    Quote Originally Posted by LX-incredible
    It really makes a difference with quality parts. Cardone axles suck and their "new" axles are actually just remans without a core charge. I got one of these for the driver's side, it was about two weeks and it started making noise again. EMPI axles are new, made with excellent quality, and under $100. GKN axles are also good, but can be pricey.
    Where's a good place to buy these EMPI axles? I need new ones, and I'd like to get something of high quality WITH a long warranty, preferably lifetime.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Quote Originally Posted by Kelvin
    http://www.drivewire.com
    CARDONE SUCKS.
    they have the same spring rate....i have nuespeed and the ride is good. not too bumpy but nice and tight in the corners.
  1. air suspension
    By ghettogeddy in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-18-2007, 09:18 AM
  2. Car Clicks when i try to start it
    By whiteboy in forum 3geez Accords
    Last Post: 12-22-2005, 04:13 AM
  3. Air Suspension
    By accord19882002 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-13-2003, 05:47 PM
  4. best suspension for my car
    By 89LXIGUY in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-24-2003, 09:10 PM
  5. Doing Suspension
    By StUpiD8000 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-26-2002, 09:52 PM
