firstly let me say hello,i have an 86 3g hatch a20a engine i bought with a blown head gasket i have changed it but three weeks on it has blown again after i changed the water pump, i torqued the head down at 10 20 30nm sequence the deck and head seems straight and replaced the thermostat,im in process of changing the head gasket a second time
at idle the temperature seems to climb and the fan only stays on for 30 sec
there seems to be no leaks in cooling system and i have bled the air also
one thing that i done was top up the radiator and resevoir with coolant
could it be too much coolant in the system
what else can i do to avoid replacing gasket a 3 time
thanks
