Results 1 to 15 of 15
Thread: help - rad rod/front beam. hermiston , oregon
    1989 4 door SEi 5spd, 1989 4dr SEi auto, 1989 SEi coupe 5spd, 1988 LXi H/B auto (kids car), 1987 LX 5 spd (other kids car), 1988 Civic 3dr
    montana
    Car is broke down in Hermiston Oregon....(not me), but my better half's kid....
    I understand the Radius rod nut cam off and since it's been loose for a while, it has worn a oblong hole in the Front beam..... Shop won't/can't fix it.
    So - i guess the beam has to be replaced....sounds like the radius rod may be OK - just needa a new nut and likely bushings and washers....
    Anyone know a place in Hermiston who can fix this at a fair price? It's at Les Schaub now and they won't let her drive it - say it's too dangerous. I bet a new nut and washer would be good enough to drive it for a while and at least gt it home (4-5 hours).
    any help would be appreciated!!!!!!!!!! ASAP
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Re: help - rad rod/front beam. hermiston , oregon
    Yeah, Les Schwab frequently tries to pull that shit. When I had my 3g I took it there to get the brakes checked and they told me the rotors were too thin and it was unsafe to drive, then tried to stick me with a $600 bill.
    It's too bad Hermiston is out in the middle of nowhere, OR. There's quite a few good honda shops in the valley.
    Sorry I can't be of more help.
    Alex
    montana
    Yeah - they say it's a liability if they let the cr leave the garage...
    i think with a anew nut and washer - it'll make it home....
    any othre ideas?
    Oct 2000
    1989 240sx FB,
    Salem, OR
    You could try forcing the issue with Schwab's. If you bitch enough, I bet they let the car go
    Then have it taken to a shop where employees don't have a cranial-rectal problem.
    I don't trust any shop that doesn't use a torque wrench, or does after using an impact gun set at 150ft lbs., to put on lugnuts.
    Alex
    montana
    I don't normally go there either....
    I just talked to the kids dad - he's going over and will tow it back to ID, if he can't get it going......
    Nov 2000
    I would actually try welding a heavy duty washer to the beam over the worn hole. That might work out just fine and be a lot cheaper and easier than trying to replace the beam.
    montana
    That's a great idea. I'll recommend that to her dad....he's not very mechinacally inclined and the kid told me she'd rather me work on it than him....but didn't want him to know that!
    I would think the the correct size washer might do the same thing! edit: i suppose it could wiggle around, and a weld would essentially create a new mounting hole......
    I wonder if you can replace the front beam without removing the radius rod?? obviously woudl remove the rad rod nuts....
    thanks
    mike
    Ichiban's Avatar
    North of You.
    It sounds like the shop is full of shit. I can't see how the radius rod would wear into the beam especially when the bushings are still in place. I'd have to see a picture of the damage before I could recommend anything, other than going to the wreckers and picking up a new front beam with the radius rods attached and swapping the whole thing.
    ICHIBAN!
    "Now, even more better!"
    cygnus x-1's Avatar
    Chicago area
    I don't see how they can not let you drive the car away. It's your car whether it's safe to drive or not.
    C|
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    exactly!!
    Let someone tell me I cant drive my car and theyll get the cops called for stealing my property!
    montana
    I agree - but I've heard they do this all the time. Aying it's a liability situation. i'd call the cops if it came to it.... In this case they said they couldn't even fix it! never cared for Les Schaub since the day the said i needed to replace ball jopints and tie rod ends on my old subaru brat when I brought it in for an alignment.... i said no thanks and later discovered nothing was rong with the front end....that and they don't blink an eye when you return a blown out tire.....blown out side wall due to cheap manuf.....
    I don't wonder if the threads from the rod coulda rubbed an obling hole in the beam.... Waiting for a report.....
    thanks for the input!
    mike
    Feb 2007
    Yes you can remove the front beam without removing the radius rods. I just had a one that was smacked really bad i the front and bent the beam all up and I wanted to drive it someplace so I replaced it.
    It's not to hard but you will have to pull on things to get the rods back into the wholes. But it should all go back together just fine once you get things into place.
    I'm in washington but still not close enough to hermiston to be much help. Let me know if you have any other questions. Also I dont know were you can go but I got my front beam from a u pull it yard for only about 12$. They only take maybe 30 minutes to pull off. It's really pretty easy.
    Ichiban's Avatar
    North of You.
    If the threads on the radius rod have chewed into the beam enough that there's a problem, I'll guarantee that the threads on the rod are trashed. Pulling the beam complete with rods is really not much more effort, come on, it's only four more bolts, right?
    ICHIBAN!
    cygnus x-1's Avatar
    Chicago area
    Quote Originally Posted by vongiese
    mike
    If they can't replace a cross member they're incompetent.
    If it's really a liability issue then here's what they need to do. Write up a ticket for what's wrong and an estimate for the work it needs. Then write on there, "Customer refused work". Have you sign it, and they keep a copy. This way they've done their due diligence and informed you that there is a problem (in writing) and shown that you made the decsion to not have the work done. You can now take the car and do whatever the hell you want.
    C|
    montana
    I'll remember that next time a shop says they can't let me drive away....but I don't go to shops....
    I guess they towed the car home to "dads" and just got a radius rod bushing, washer and nut and put it back on and the car is fine....
    I'll take a look at it next time she's here and see what the damage really is.
    As far as removing the front beam without removig the radius rods - I thought the 2 bolts holding the rear end of the raduis rod could not be removed without removing the axles?.....aren't the axles in the way -- i.e. not enough clearance to get the bolts out?
    thanks for all your suggestions....
    mike
  1. Extra holes in the front beam
    By carotman in forum 3geez Accords
    Last Post: 09-30-2006, 05:52 AM
  2. Torque Rod-Front Beam
    By 1989accordaz in forum 3geez Accords
    Last Post: 03-20-2006, 08:26 PM
  3. Effects of Lowering front beam ?
    By A20A1 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-15-2005, 10:34 AM
  4. Tubular front beam idea
    By AccordEpicenter in forum Performance
    Last Post: 03-21-2005, 05:48 PM
