Results 1 to 18 of 18
Thread: how to bend fender back near door?
    Ok I'm not really sure how this happened.. i think perhaps my door trim got caught on my fender and pushed it in.. but now I can't open the door at all for risk of bending the fender even more and chipping the paint more as well.
    Is there a cheap/easy way to pull or push the fender back into shape so i can open the door? from what I understand I can't pull the fender without opening the door.
    anyways yeah thanks for the help
    Re: how to bend fender back near door?
    1st take off mud flap
    2nd take out wheel well lineing
    3rd put your hand behinf the fender
    4th yank the the fender towards you
    5th once the fender it out farther then the door open the door and remove the 2bolts behind it
    ^^ yup I think it does need to come off a little frantik
    ^wut he said
    2ndGenGuy
    Guest
    I had to do the same thing, my friends dad hit my car and pushed in the fender EXACTLY like that. Just take off that molding, and use something to pry the fender back out straight. Just be gentle and take your time, you should be just fine.
    Keep bending it out until the door molding doesn't hit or catch on it again. It might look like it's perfect, but the molding might still hit. Just keep bending it slightly. It will eventually come clear out. Be even, and spread the point at which you're bending out as much as possible, or you'll wind up with a crease.
    dammit i was a total dumbass and tried to open the door without thinking and now there's a small crease near the edge
    lol i asked u if i should do that on aim and u said the bolt was behind the fender or some shit :p
    lol i thout u ment the fender bolt lol no u just grab that lining and rip it out and thow it in trash cuz u well never get it back on right lol
    uhh.. there's gotta be a better way than "ripping out and throwing it in the trash"
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    You need to remove those screw-rivets, either by unscrewing the centers with very little pressure, or by prying them out with an icepick. With the lining removed, you should be able to push the fender out enough to get the door open, and gain access to the bolts. Throwing the lining away would be as stupid as using walmart primer on bare metal.
    CARDONE SUCKS.
    well if thay are riped and cut up like mine thay dont go back on but if thay in good cond thay should id just use new scews tho cuz the plastic scews suck
    Sep 2006
    Tucson, AZ
    Quote Originally Posted by Civic Accord Honda88LXi
    They are not screws, they are screw-rivets, and they are easy to remove if you know what you're doing.
    CARDONE SUCKS.
    where are the screw rivets? behind the mud flap?
    Sep 2006
    Tucson, AZ
    There are 5 or so right behind the lip of the wheel well. There are some further back as well. There is like 10 or 12 of them in total. You will also need to remove the mud flap. It will be easiest to remove the wheel.
    CARDONE SUCKS.
    Quote Originally Posted by LX-incredible
    so how u take them off ;/
    i used a tool like a door panel removal tool....it looks like a V Shaped and you just pry and the rivet thing will come off.
    Banned ahmad89's Avatar
    Dec 2006
    Mine is bent like that too but its much worse, there are some creases at the edge of the fender, i think my molding caught onto it or something.
    nice. i learn that 4 fenders later
    Sep 2006
    Tucson, AZ
    You remove the centers and they pull out by hand.
    CARDONE SUCKS.
  1. can you bend rims from being parked too long
    Last Post: 10-27-2012, 12:42 PM
  2. Guess whos back!? back again .. raun is back, tell your friends ..
    Last Post: 05-12-2012, 07:16 AM
  3. changing back door small glass on 89 lxi
    By thh420 in forum Interior & Exterior Care
    Last Post: 07-29-2005, 09:56 AM
  4. Did my valves bend...........................
    By hondacowboy003 in forum 3geez Accords
    Last Post: 07-06-2003, 08:03 AM
  5. **Need Help to put Door Molding back on Some 1 Please Help***
    By 89AccordLXI666 in forum Classic Honda Community Chat
    Last Post: 06-08-2003, 06:57 AM
