Fuzy Navel
Hey, Not sure what is wrong but have idea... Ok I thought I had maybe a road bearing going out or something But i changed the oil, oil filter and put thicker oil in... Didnt help any. Thought maybe it was Water pump because it was the orignal one that came from honda so I changed it.... Didnt work What it is, is a really annoying clicking noise around 2,000 and up it wasent really bad at first and it only happened when the car get warmed up so i figure oil or antifreeze.... Well now it does it alittle bit right at car start then when the car gets fully warmed up it is really bad and loud clicking noise in any gear parked or not parked... and when I drive and let go of the gas it just under idles and trys to die and then dies if I don't add any gas... So I have honda book and 2 other people telling me most likely timing belt tensioner.... What do you think? The sound comes from under the intake manny as far as i can tell but it also echos because it comes from the belt system too..
Oh and I have brand new water pump, Alternator, and no belt on Air conditoner and its not the power steering pump already tested that
