Results 1 to 25 of 27
Thread: autometer RPM TACH
    DX User spades's Avatar
    Mar 2007
    1989 honda accord ex
    toronto canada
    autometer RPM TACH
    can anyone tell me how to install a autometer tach in my 89 accord i cant seem to find a how to toppic for this??
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Re: autometer RPM TACH
    the instructions come with the tach, or you can download them from the auto meter website.
    Also look as the external ignition coil how to to find out which wires to use... since the stock coil has multiple wires to it.
    https://www.3geez.com/forum/showthread.php?t=57448
    make sure you cut the correct wires on the back of the tach to set it up for 4 cylinder applications.
    Mar 2007
    toronto canada
    thanks for the fast reply ill check it out
    Quote Originally Posted by spades
    thats cause are car's come stock with a tach and if u notice any pics of any of our cars no one has them lol there kinda rice unless u actually need to dial in the rpm's at the track
    Mar 2007
    toronto canada
    the instructions say to hook it to the ground on coil so do i hook it to both blue wires or just one of them?
    Mar 2007
    toronto canada
    i got it with a AutoMeter Pro-Comp Ultra-Lite Volt Meter 8-18 Volts
    AutoMeter Sport-Comp Air/Fuel Gauge
    AutoMeter Sport-Comp 10,000 RPM TACH
    so i thought what the heck hook it up to
    ummm thats a good question id think one would be ok but then again theres a reason for 2 of them
    Mar 2007
    toronto canada
    i know im crazy LOL just like the way it looked i got all 3 guages for $150.00
    Mar 2007
    toronto canada
    and both blues are on a diff connector
    try one then the other see what happens if anything go and get a msd blaster coil then u dont have to worry about it lol
    Mar 2007
    toronto canada
    cool thanks for the info
    sounds good where are you going to mount it....
    i want a obd-1 swap so i can plug in my laptop to my car and then i would just look at the laptop and check out the RPMs
    why go through all the hassle of doing that, when you can just look at the tach in you gauge cluster =P
    shepherd79's Avatar
    Falling Waters, WV USA
    i would convert to diff coil first and then connect the external tach.
    as far as your gauges, the voltmeter one would be the one more use to you than Air/fuel or tach.
    our cars have tach so we don't need it and air/fuel gauge doesn't work at idle or regular driving. it only works when you floor it in every gear. basicly you just got a nice light show in a car.
    Mar 2007
    toronto canada
    like i said i just like the look and the price was right. im going to put the tach on the right side of the cluster
    Mar 2007
    toronto canada
    does anyone know if you need to use both blue wires
    "DRIVE IT LIKE YOU OWN IT"
    89T's Avatar
    Apr 2004
    in my opinion, I think you would be happier with it on the left side.
    i have mine on the right and hate it there. At night i have to throw a ball cap over it to not call so much attention to it. The light in it is bright as hell too.
    this is only an opinion so take it for what it's worth.
    un-motivated!
    3GR
    Mar 2007
    toronto canada
    thx how did you hook it up. i still have the stock coil so i has the 2 connectors and the spot with for the coil wire each connector has a blue wire and a black with yellow stripe
    89T's Avatar
    Apr 2004
    the blue wire that runs to the distributer.
    un-motivated!
    3GR
    Mar 2007
    toronto canada
    thx
    because you can tune the car...and make it go faster. plus its digital
    LX User Versanick's Avatar
    Jun 2002
    1986 Honda Accord LX Sedan (RIP), 1989 (same) RIP, 86 Hatch Lx-i, JDM b20a, Gude headpkg, AEM cam gears/cai, thermal xhst, 2.5/3" lowrd tokico/groundctrl, 17" Seneca whls, hypereutectic pistons, .020" over, 13:1 comp
    Upstate NY
    Often, the aftermarket autometer tach connected directly to your coil is more accurate than your stock in-dash tach. My stock tach would read about 6700rpm sometimes at rev limit, while the autometer read right under 7000 (which is the 6950 I assume it should be). Not probably enough of a difference to matter most of the time. Often, they read the same.
    I have an 8k and 10k autometer. I think at this point, I just use it because I like the shift light.
    Mar 2007
    toronto canada
    you guys rock i got it to work b4 i had this prob with my car but looks great and once i get it fixed ill post pics
    A20A1's Avatar
    Sep 2001
    If only I was manual
    ^^^your CAH phase
  1. Autometer gauges/ AEM widebandO2
    By Justin86 in forum For Sale
    Last Post: 04-01-2009, 10:20 AM
  2. MSD tach adapter driving stock tach
    Last Post: 05-11-2008, 09:57 PM
  3. FS:Autometer Air/Fuel Gauge
    By 88LXi68 in forum Trading Post
    Last Post: 03-21-2004, 11:32 AM
  4. Short shifter & Autometer Gauges!
    By BITESIZE in forum Classic Honda Pics & Videos
    Last Post: 02-17-2004, 12:13 AM
  5. F/S Autometer 2 1/16 gauges
    By 88turboaccord in forum Trading Post
    Last Post: 08-19-2003, 10:38 AM
