Most local "experts" have said that the trick is to use relatively small choke to get any kind of drivability. I started with 36 mm chokes, then 34 mm and finally 32 mm chokes. Note that the engine size in my Mini is 1380 cc and usually it uses either 36 mm or 38 mm chokes in n/a street engines and 38 mm or 40 mm in serious race engines.
With larger chokes the hig speed mixture could be made rich enough but the transition from idle jet to main jet was just a big hole. Anothe emulsion tube fixed the transition but then there was no fuel under boost... Going to smaller chokes did help the drivability enormously but did not cure it completely.
Now, the real trick was to locate a book called "Turbomania" by Bob Tomlinson. A guy called Dan Noble in San Diego USA hinted about the book that contains a load of info about turbo VWs. Located and bought. The trick here is to use a restriction at the carb mouth, like a stub stack but with a bore smaller than the carb bore. Judging by the jetting info supplied it seems that the size of the restriction is about the size of the choke or even less. So I turned a pair of inserts with 34 mm ID for my stub stacks and refitted the 34 mm chokes. Well you know the old wisdom: only change one thing at a time...
Now the engine works just as well with the 34 mm chokes + restrictions as with 32 mm chokes. It would probably be better with even smaller ID restrictions. By making the carb pressure sensitive it has made the jetting a bit easier. Still the jet sizes look a bit large compared to choke size but smaller simply will not work... Still the jetting is not perfect: there is a spot at about 2500 rpm where the engine hesitates: depending on the idle jet holder vs. emulsion tube combo it´s either rich or lean. But with WOT it runs very nice. I would like the engine to run smoothly from idle to max rev on 4th gear. Now it stumbles at about the said 2500 rpm. Actually no big deal once you know it is happening, simply go to 3rd gear and hit it.
I have experience only with Dellorto carbs but similar approach can possibly be adapted to DCOE range. Dellorto turbo carbs had seals on throttle shafts plus rubber 0-rings for idle screws. All drilling plugs had been sealed with lacquer. The gaskets were made of rubber.
A couple of years ago I did phone around about DCOE suitability and was informed that 151 and especially 152 type Webers were suitable for blow thru out of the box.
