Just a thought on the ignition side...as a cheap ass mod, maybe this would work but, it would annoy the r+r tuner!..if it worked!! If i could reverse the role of the vacume advance diapragm and have it push instead of pull...taking it apart and somehow putting the spring under the valve causing it to result push rather than pull! and using the boost guage line to push the diapragm and retard the timing under boost!! Also, then i could control the amount of retard by having an inline tap..which could then have a additional under hood pressure guage to show how much pressure is coming thru the tap, if ness'ry!! What do u think could it work? maybe i'm overthinking this and my worlds too ideal!!?
