Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 80
Thread: Project B18a swap
  1. #51
    LX User ESDEEZ's Avatar
    Jul 2006
    2.0 UKDM EX-I 4WALB 3g accord maroon thats back in service after a year of standing in a field. also lookin 4 a 3g in SL
    England again. then sri lanka....again
    Re: Project B18a swap
    94? 194!?
    We have fast cars but we have less time. We have wide screen tvs but narrower minds.
  2. #52
    i dunno, i probably need glasses (or clean the screen) but that's what it says here:
    maybe i just dont know how to read it
  3. #53
    LXi User Vector's Avatar
    88 Accord DX-RWD
    Kelowna BC
    yea well... correct me if i'm wrong... but don't they call the mustang dyno the heart breaker.... well yea i wasn't that impressed with the scores myself... but after seeing what some of the other 4 cyls pulled on it i didn't feel so bad...
    that was a 4th gear pull to btw..
  4. #54
    so how much for a set of custom mounts lol
    im kinda serios about it i have an extra accord laying around lol
  5. #55
    SEi User ZackieDarko's Avatar
    yeah really how much to duplicate these things
  6. #56
    Quote Originally Posted by Vector View Post
    SOmething is wrong with that engine, you need to check it out. YOu should be ranging around 115-120 hp with that engine.
  7. #57
    You'll have to explain what holds your front struts in the car sometime as well.
  8. #58
    88 Accord DX-RWD
    Kelowna BC
    side mounts:
    i used caster brackets from princess auto... heavy duty ones.... these will not break rated at holding up to 5,000lb each also had to be big enough for the teg mount to fit in.
    rear mount:
    used a20 dog bone, so the back mount ties the engine to the firewall, not the cross member, all i did for that was cut and bent it at .... 20 degree so it would clear the lines and firewall and reach the tegs tranny mount bracket.
    front mount:
    this took the most work, i cut the end of a bent lca which still had a good bushing in it and welded it to a 3/4" thick x 6" long steel. went back to princess auto and bought some 3mm x 2" x 4ft long steel and made the front bracket that bolts to the front x member.
    my suspension:
    what are those???!!?!?1?!( i've gotten that alot when i race)
    those are my hats... i offset the shocks to compensate for lowering the car... front and back.. i did this so i can run oem shocks and not destroy them every 2-3 months. in turn it also helps with limiting body roll and the ride comfort.... well with coil overs its pretty stiff... but the shocks take to it pretty good... the car does not excessively bounce and is fairly impressive in the corners.
    ps. i am using the axels and intermediate shaft that came with the engine.
    more to come in abit... got some work to do..
  9. #59
    well its a mustang dyno. but yeah....next time do 3rd gear pulls. that is what i dynoed my car with...and i pulled 109whp...so like 125 to the crank.
    side mounts:
    rear mount:
    front mount:
    my suspension:
    thats cool, very clever thinking
    and whats the difference between the mustang dyno & any other dyno?
  11. #61
    88 Accord DX-RWD
    Kelowna BC
    that part i'm not entirely sure of in terms of how it works... the guy siad somthing about it having a brake... so it can simulate air resistance and stuff... thats all i got from the conversation lol
  12. #62
    Basically it underrates the engine HP/TQ compared to other dynos.
  13. #63
    Mustang reads low but your rpm ? 6250 dont those cars goto like 7500?
    I like the strut idea thats really cool. I still dont see what holds the top hats in the car but not important at all. Neat set up.
  14. #64
    88 Accord DX-RWD
    Kelowna BC
    i've consolidated my mods and pics into 1 section right here
    there are closer pics of the strut towers and what i did with the suspension.
    7200 is rev limit on the b18a1 as far as i know...
  15. #65
    i love how simple that is
  16. #66
    Alright dude, that suspension stuff is pretty ingenious. That would work PERFECTLY with the 89 civic struts. There would be no need for modification. You could just bolt them in. Very nice setup on the engine, and great suspension mod. I will have to try that with my next 3gee.
  17. #67
    88 Accord DX-RWD
    Kelowna BC
    for the suspension mods, i used 4" x 1/2" carriage bolts and alot of nuts... i double nutted everything because if anything came loose while racing... lol that could be relatively dangerous...
    i had thought about using civic shocks since they are widely available... i know where i can get some 6 way konis probably cheap... i might just do that.
    are they longer than the 3g shocks?
  18. #68
    Yes they are much longer then the 3gee accord, but they fit in the perch like a glove. With that mod you have there it would eliminate the headache I had to go through.
  19. #69
    88 Accord DX-RWD
    Kelowna BC
    cool.. guess this opens up possibilities for other shocks then.
  20. #70
    Honestly any shock that would work for an 88-89 civic would work for our car with that mod. So any shock you want you can get. Now you need to figure out a way to make the shorter shocks work in the rear .
  21. #71
    88 Accord DX-RWD
    Kelowna BC
    how much shorter.... i bet i have an idea for that..
  22. #72
    I have never physically measure them, but somewhere in the realm of 1 1/2" to 2"'s shorter. They work good if you want to dump the car, but not very practical for most daily drivers.
  23. #73
    DX User sleeperheaven's Avatar
    Mar 2004
    1988 Honda Accord DX
    POMONA PARK, FL
    one question what spindles did you use
  24. #74
    88 Accord DX-RWD
    Kelowna BC
    Quote Originally Posted by sleeperheaven View Post
    the accords... just popped the dust sheilds off.
  25. #75
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    wow
    good work.
    Mustang dynos definately kill ur joy. if you would have dynoed on a dynojet it probably been like 105 at the wheels.
    somethig definately sems wrong since hey stopped the run at 6200 rpm and by looking at the dyno plot it still had some left in it. I ran the p75 and hit the rev limit with the a20 like nothing. I think its like 7000 or 7200 rpm.
    I definately like your top hat idea.
    As far as the rear civic struts being to short you can use your top hat idea but backwards and make it sit under the car instead of inside. You look lik eyou have some good problem solving skills so that shouldnt be a prolem for you.
  1. PROJECT: A20A to B18A Tranny Adapter Plate
    By SQ is the SQUAD in forum Restoration & Custom Fabrication
    Last Post: 04-30-2024, 10:38 AM
  2. Turbo Vic's 3g OBD-0 B18A Swap Thread
    By SQ is the SQUAD in forum General Engine Swaps
    Last Post: 11-25-2012, 04:35 PM
  3. Possible B18a swap..
    By 87roach in forum JDM B18A / B20A Swap Tech
    Last Post: 03-31-2007, 09:08 PM
  4. b18a swap
    By snipz in forum Performance
    Last Post: 01-04-2006, 10:16 AM
  5. help!! b18a swap on '88 dx
    By aCCorDtYpeSloW in forum General Engine Swaps
    Last Post: 03-23-2003, 10:17 PM
