Results 1 to 10 of 10
Thread: 4th generation map sensor
    LX User Beanshonda55's Avatar
    Apr 2006
    1989/honda/accord/lxi
    lincoln, nebraska
    SO i just got my 4th generation mapsenor and i installed it. My car idialed really low and almost died and after about a minute running the check engine like came on. SO i reinstalled mystock one and it ran fine. Any body no what my problem is.
    Thanks Adam
    Re: 4th generation map sensor
    maybe you just got a bad sensor.
    thats probably it, try another one
    Apr 2006
    lincoln, nebraska
    i dont think its that, but i guess it could be. but when u install it are u suppose to reset ur ecu because ididnt i think i was supposed to but not sure?
    I just swapped mine out, nothing else needed to do
    yeah i just swaped mine also....didnt even have to restart or reset the ecu....also did you splice it..it had 3 wires that have to be connected right.
    Apr 2006
    lincoln, nebraska
    its the one i got of of gfrg88 and it all looks fine. ill take of the tape and make sure there all connected properly.
    Apr 2006
    lincoln, nebraska
    well i just went out and i started it and let it idle for a while with the 4th generation map sensor and it was actually worked like normal but the check engine light was still on and then i killed it and startedf it right back and then it was back to the crappy idle and shitty running but then went back to normal and right when it went back to normal idel and running the check engine light came on.
    Apr 2006
    lincoln, nebraska
    bump
    two things:
    1. it is probably not wired properly or
    2. the sensor is dead.
    you won't see big gains. you just going to waist fuel with 4G SENSOR.
    just keep the stock one.
  1. My 3rd generation
    By flyingmen4 in forum Classic Honda Pics & Videos
    Last Post: 02-03-2006, 10:30 PM
  2. Need help! Broke a sensor wire (green sensor)
    By SMaurer32 in forum EFI Tech
    Last Post: 10-31-2005, 08:06 AM
  3. 4th generation
    By Hakaveli in forum Interior & Exterior Care
    Last Post: 01-15-2003, 02:08 PM
  4. 4 Generation BW kit
    Last Post: 01-02-2003, 07:37 PM
  5. 4th Generation
    By youngholla in forum Classic Honda Community Chat
    Last Post: 07-13-2002, 12:13 AM
