Page 6 of 8 FirstFirst ... 2345678 LastLast
Results 126 to 150 of 177
Thread: I found the solution to the B20A "RARE" transmission.
  1. #126
    cygnus x-1's Avatar
    Chicago area
    re: I found the solution to the B20A "RARE" transmission.
    it's just a B18A gearbox, the B18A engine is a completely different engine from a B18A1, and gearboxes are not interchangable between them
    Ok, that's why I asked about USDM vs JDM/EDM. I know that B18A is not the same as B18Ax. But Carotman said:
    Yes, I wanted to keep this simple. All the A series for our cars have the same block casting. Same goes with the B series made for our cars.
    So in the diagram A20A could also mean A20A[1/2/3/4] as far as the engine blocks. But not so for the B18A and B18A1? This is why I'm confused.
    I guess in the end all I really want to know is if I can put any other gearbox on my A20Ax engine and A20Ax bellhousing.
    Or should I just go away? :lol: <--(WTF? Are smilies disabled in this thread?)
    C|
  2. #127
    2ndGenGuy
    Guest
    I think Carot's chart is only in relation to what came in 3g Accords and 2g Preludes. Sooo.... if someone wanted to expand on that, then we'd want to start adding in the other stuffs or make another chart. We know Carot's chart is 100% true, but we haven't discovered first hand what works as far as other gearboxen outside the mid 80's Accord/Prelude family. Or did I miss that part somewhere else in the thread?
    :) <--- SRSLY WTF!
  3. #128
    cygnus x-1's Avatar
    Chicago area
    :) <--- SRSLY WTF!
    Ohh, I think I see what you/he means now. There was no B18Ax in any 3g Accord or 2g Prelude, so those don't count. There was a 3g Accord B18A but not a B18A1. Got it.
    C|
  4. #129
    Jul 2002
    a pile of lawn ornaments
    Newtown, CT
    i just got a migrane.
    -Mark D.
  5. #130
    :werd:
  6. #131
    and i have one for sale now 300 shipped kthx
  7. #132
    Feb 2009
    Hey All, Have got a Honda Accord B20a motor here in NZ. The auto has decided to die on me - it's done 280,000kms so can't complain. Thing is I want to replace the tranny cos I've really looked after the car. So have searched the site and found Carotmans guide re: which trans comes from which Chassis/ Engine. According to that it should be the F4-6000001 transmission. Question is; I can't get hold of an F4 so can I use one of the N6 transmissions and just bolt it on and go without any mods? Appreciate any help on this and apologies if I shouldn't have tagged this onto this thread. Cheers, Dave
  8. #133
    LXi User Steve_Si's Avatar
    1986 Honda Accord 2.0Si
    Christchurch, New Zealand
    Just get a 5 speed box from another 2.0Si. You'll need pedal box, shifter, linkages and the 1/2 shaft + obviously the tranny, clutch, clutch cable etc.
    The 5 speed box from the EXL-S does not use a 1/2 shaft and is prone to bad torque steer when paired with a B20A.
    This entire thread is about pairing a USDM 5 speed with a JDM B20A. You should be able to find the JDM 5 speed easily enough! Didn't take me long :P
  9. #134
    Quote Originally Posted by KiwiDave View Post
    two words, MANUAL SWAP lol
    either that or buy my auto box from me off trademe :P
  10. #135
    Quote Originally Posted by Steve_Si View Post
    If he is from the south island he should be able to find a manual swap piece of piss as most accords down there are manual, up north here they are all fail and automatic
  11. #136
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    domt see many manual si accords down here
    most are like mine and converted from auto .
    talked to a wrecker mate a while back and its getting hard to find b2k5 boxs down here now.
    and finding black top b20a accord motors is starting to get hard to
    and where you from kiwi dave?
    mainlander or that other island up north
  12. #137
    lol your south island used to be good till chch moved in
    i would also like to know what island hes from, also who cares about finding blacktop motors, gold top motors are the win engine :)
  13. #138
    Sep 2007
    new zealand
    haha, tell me bout chch mate
    bout my least fav city after auckland.
    waayyy to busy for me
    to fast, gimme slow laid back invers anyday
    gold tops are poolude motors so can stay in pooludes
  14. #139
    Feb 2009
    I'm from the North Island. The motor is a gold top and runs well but the body is falling apart so won't be converting to manual.
    AccordB20A- you said your box was an L4 so can't use.
    Anyone know for sure whether I can use the N6 transmissions instead of the F4? Carotman are you around? You seem to know the most - any idea? Have searched the forums and can't find the answer. Should I start another thread?
  15. #140
    well a b20 gearbox fits any accord b20a so it will still work, mines probably out of a 2g prelude but it will still work on any accord
  16. #141
    3g prelude b20 gearboxes don't :P
  17. #142
    3g preludes arent in out vocabulary , they are not counted as they are B20A5 motors and therefor fail
  18. #143
    Sep 2007
    new zealand
    pooludes man
    get it right, P O O L U D E S
  19. #144
    pooludes man
    yeah poolude lol
    you best replace that intake and ecu man, blacktop engines are as close to the poolude b20a5's as hell lol
  20. #145
    Sep 2007
    new zealand
    yeah poolude lol
    my motor leans forwards, not backwards
    thats far enuff removed from a 3g poolude for me
  21. #146
    so can i still use the b20a5 lighten flywheel with the a20 clutch? for the b18 housing?
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    The B20A5 flywheel won't work with the A20 clutch
  23. #148
    not to mention the starter motor wont engage on it. you have to use a 1986-1987 gold rocker covered A20A clutch with a recessed flywheel. it is the only a20 flywheel that fits the B20A
  24. #149
    LX User OldSchool86's Avatar
    Sep 2008
    1986 Accord Lx 5Speed
    A T L a n t a, GA
    That's right. I found THE solution to the B20A "RARE" transmission.
    We all know that the B20A can be somewhat easy to find but finding the 5 speed transmission can be a real challenge.
    I've noticed that the B18A (The B20A little cousin) has a transmission configuration really similar to the A20A. I've been wondering for some time if the B18A transmission is similar to the A20A. Well, it turns out it shares the same fucking tranny case and cover. Excuse my language but I'm so amazed by that discovery that I don't know why I didn't look into this earlier.
    I checked my JDM parts catalog today and compared part numbers with the B18A.
    Here are some revelant part B18A numbers:
    Tranny case: 21200-PC8-J52
    Tranny end cover: 21310-PC8-961
    Tranny end cover gasket: 21395-689-000
    Oil Seal: 91206-PC8-003
    T/0 Bearing: 22810-PC8-921
    Mainshaft: 23211-PC8-J30
    Countershaft: 23220-PC8-671
    Fork, Low Gearshift: 24221-PC8-920
    Differential Case: 41310-PC8-621
    I know it may seem late for this post but its the first that i've seen it but my A20A1 5speed tranny case # is not the same. mine is 21200-PC8-J00. am i missing somthing?
  25. #150
    Sep 2008
    A T L a n t a, GA
    what i have found is:
    86 only had the 21200-PC8-J00
    87 had both the 21200-PC8-J00 & J52
    88-89 Had only the 21200-PC8-J52
    What is the defferance between the two tranny's?
  1. My rare JDM RHD 1980 Prelude XR found in WV
    By EM1 ADCT in forum 1geez Accords
    Last Post: 09-21-2012, 11:41 AM
  2. found a gold top b20a for sale on the cheep
    By labeledsk8r in forum Classic Honda Community Chat
    Last Post: 10-15-2010, 03:26 AM
  3. JDM B20a Found(Maybe), But Worth It?
    By Listen2myBASS in forum Classic Honda Community Chat
    Last Post: 09-14-2006, 02:12 PM
  4. Found B20A!!! But.....
    By Dibbs in forum JDM B18A / B20A Swap Tech
    Last Post: 07-11-2003, 12:50 PM
  5. found a website that sells b20a for accord
    By Immeraufdemhund in forum Trading Post
    Last Post: 07-03-2003, 06:35 AM
