Page 1 of 8 12345 ... LastLast
Results 1 to 25 of 177
Thread: I found the solution to the B20A "RARE" transmission.
    carotman's Avatar
    Montreal South Shore
    That's right. I found THE solution to the B20A "RARE" transmission.
    We all know that the B20A can be somewhat easy to find but finding the 5 speed transmission can be a real challenge.
    I've noticed that the B18A (The B20A little cousin) has a transmission configuration really similar to the A20A. I've been wondering for some time if the B18A transmission is similar to the A20A. Well, it turns out it shares the same transmission case and cover.
    I checked my JDM parts catalog today and compared part numbers with the B18A.
    Here are some relevant part B18A numbers:
    Transmission case: 21200-PC8-J52
    Transmission end cover: 21310-PC8-961
    Transmission end cover gasket: 21395-689-000
    Oil Seal: 91206-PC8-003
    T/O Bearing: 22810-PC8-921
    Mainshaft: 23211-PC8-J30
    Countershaft: 23220-PC8-671
    Fork, Low Gearshift: 24221-PC8-920
    Differential Case: 41310-PC8-621
    ALL, and I mean ALL these parts can be cross referenced at your local Honda dealer in North America. These parts are all from the JDM B18A transmission that WILL bolt up to the JDM B20A engine.
    You can look for yourself by entering the part numbers here: www.slhondaparts.com
    So far, I realized that all you need to install an A20A transmission on a B20A is the B18A bell housing. That thing can easily be had from New-Zealand or any other country that had JDM imports.
    Of course, the A20A transmission has longer gears but you can always use the 1st gen Integra internals and you'll get a transmission that's really similar to the B2K5 or F2K5 from the JDM B20A.
    There "might" be some differences that would not work but so far, every part matches, even the bearings and seals. All you would need to do is get that B18A bell housing, install it on your A20A transmission, use the A20A clutch and you're on!
    I need these parts!
    re: I found the solution to the B20A "RARE" transmission.
    nice make sure bullurd sees this so he dosent sell his motor
    fugging awesome one carotman :D :D :D :thumbup:
    Idaho
    That's indeed an uber good find! Kudos!
    I think I deserve a beer now, don't I?
    :cheers:
    good job figuring this out c-man :thumbup:
    [edit: and why not smilies here :(]
    carotman's Avatar
    I noticed that even the B18A AND B20A auto tranny has the same case as the A20A auto tranny... This means only the bellhousing is different between the A20A and B18A/B20A auto trannies.
    So, if you have a low miles B20A auto tranny, don't throw it in the garbage, they are of some use for the guys here that blew their A20A trannies.
    I'm glad I kept my B20A tranny :p
    I need these parts!
    time to give steve_si a call....
    LXi User Steve_Si's Avatar
    1986 Honda Accord 2.0Si
    Christchurch, New Zealand
    So can you confirm that all I need to send Bullard123 is the bellhousing? If so I can take the rest to the metal recycling centre.
    Also, will the bellhousing from an auto B18A transmission be useful to those with a manual transmission from an A20A?
    carotman's Avatar
    Hmm. I'll have to compare every single part to comfirm that it's 100% the same. Give me an hour and I'll be able to do it I guess. 3geez is worth more than an hour of my time hehe.
    And yes, the B18A/B20A auto bellhousing is all you would need to install an A20A auto tranny to a B20A.
    Edit: Well, I just thought about something
    IF the mainshaft, countershaft, differential, shift forks and bearings are the same, the A20A tranny will work with a B18A bellhousing.
    I compared the gears and they come up on www.slhondaparts.com...
    Great news.
    I need these parts!
    Idaho
    ^^^You are 3geezus!
    carotman's Avatar
    Steve (or anyone from NZ)
    If you come by any DEAD B18A tranny, this is worth GOLD for us guys in North America. You can probably sell the bellhousing alone for 3 times the price of the dead tranny :p
    I need these parts!
    Im sorry, but is this an april fools joke?
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Hmmm I hope you are right Carotman. Cause I didn't want to run into anymore surprises lol. I knew I was on to something when my stage1 clutch from my A20 bolted up directly to the B20A. Thanks for completing the rest of that research too. It seems something good always comes out of a bad situation. Now we can see more B20a geeez riding around. And Steve I'll be looking forward to your Pm with the costs.
    Ichiban's Avatar
    North of You.
    I wonder if advance adapters or downey would cast us more B18A bellhousings if we sent them one and asked for copies?
    ICHIBAN!
    "Now, even more better!"
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Oh and this thread should be a sticky Carotman :)
    carotman's Avatar
    Oh, one more thing, you'll probably still need the B18A rear bracket to go with the bellhousing. The bracket doesn't cross reference with the A20A
    You'll need the flywheel cover too.
    I need these parts!
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Alright Thanks. I hope Steve Si see's this too
    Great Job!
    SEi User ZackieDarko's Avatar
    good god i hope this isnt an april fools joke
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Hey Carotman shouldn't the rear bracket and flycover from a B20a tranny work?? Steve might have a hardtime trying to find another B18 5 speed donor car because I'm sure the flywheel cover isn't on the tranny right?
    who really needs a flywheel cover i havent had one on mine for like a year at least lol it hasent made a dif at all
    cant ya just make one with some cheap metal anyway?
    LXi User L3G10N's Avatar
    Princeville, Quebec
    So Carot, are we going back together next week buying all the B20A lying down in the JDM shop? lol They almost all have automatic tranny :)
    My 86 custom build thread
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    Good find Carot!
    Glad to see ur still out there diggin up info for the rest of us. Makes we want to pick up a b20 and swap all my stuff over :D
    carotman's Avatar
    I guess the B20A rear bracket will work. I'll check that later tonight.
    Legion, we'll buy the "useless" B20A auto trannies for like 50 bucks at the importers :D
    I need these parts!
  1. My rare JDM RHD 1980 Prelude XR found in WV
    By EM1 ADCT in forum 1geez Accords
    Last Post: 09-21-2012, 11:41 AM
  2. found a gold top b20a for sale on the cheep
    By labeledsk8r in forum Classic Honda Community Chat
    Last Post: 10-15-2010, 03:26 AM
  3. JDM B20a Found(Maybe), But Worth It?
    By Listen2myBASS in forum Classic Honda Community Chat
    Last Post: 09-14-2006, 02:12 PM
  4. Found B20A!!! But.....
    By Dibbs in forum JDM B18A / B20A Swap Tech
    Last Post: 07-11-2003, 12:50 PM
  5. found a website that sells b20a for accord
    By Immeraufdemhund in forum Trading Post
    Last Post: 07-03-2003, 06:35 AM
