Here are a few pics
Pic one is the float adjustment screw, float needle, air fuel adjustment screw, and some o-rings.
Before making any adjustments to the float level you think is set wrong... make sure that it isn't a bad fuel pump or clogged filter causing the low fuel level.
First remove the air box to get a good look at the carburetor... if you need to have the carb running while you have the air box removed look at the link below.
https://www.3geez.com/forum/showthread.php?t=38108
Here is a pic of the air box with the lid off.
Here is the stock carburetor
Here is a close up of the carburetor, this is the right side of the carb if you are standing at the front of the car facing the motor.
The red line represents where the fuel level inside the float bowl should be when looking thru the glass.
The red line is the correct fuel level when the car is running.
If the pump and fuel filters are operating correctly and the fuel level is still low then adjust the float setting with the float adjustment screw.
If the float level is too high it could be a leaking o-ring, there are two rubber o-rings on the float adjustment screw.
To access the float and remove the float look at the rebuild links above in the first two posts.
The float valve is easy to get out once you remove the float pin
Below is an image of the float valve screwed in as if it were being removed but it is blocked by the float and the float stop. If you remove the pin you can remove the float and then remove the float valve.
If you try just removing the float stop to remove the float vavle... then you'll run into problems when the float level gets too low... the float needle might fall out and you'll end up with a serious gas leak and an over filled float bowl...
Be cautious cause the float valve o-rings are easily damaged, especially used o-rings... so constant adjustment of the float setting is not advised after the carb has been rebuilt... so it is important to rememver where the float screw was set at before it was removed... this will minimize how much you need to turn the screw later once you install the carb and run the car.
