2ndGenGuy
Once a crank has been messed on a Honda engine, you can no longer use the color-coded bearings. If it's been scored, and you have to get it turned, you are now using the 0.25 0.50 and 0.75mm bearings.
You can't mess with the crank journals with any kind of cloth or dremel or anything. If it's not perfectly round to a machined tolerance, you're going to spin that bearing again.
And if you do take your crank to be turned, it needs to be re-hardened. That's why Honda says to THROW AWAY your crank, because once it's turned the hardened metal on the outside is gone.
