Results 1 to 6 of 6
Thread: What Engine Model is it?
    DX User musclecarboy's Avatar
    Mar 2007
    88 Accord 4-dr (my bro's car)
    Toronto, ON
    Hi everyone.
    In the auto shop at my school there's AT LEAST 20 Honda 4-cyl engines in random places but I'm not sure what kind they are, what size, etc. Is there any way of finding this out by just looking at them?
    Thanks guys.
    2ndGenGuy
    Guest
    Re: What Engine Model is it?
    There is usually a number stamped on the engine. Like B20A, D16Z6, A20A1, A20A3. The first letter usually signifies the engine series, the displacement is the numbers, and the sub-series is the second numbers. Get that number and just Google it and you'll get lots of results.
    Older engines may not be stamped, I'm not sure. Typically they are E-series engines. E-series are almost all CVCC engines, so that is usually a hint...
    snoopyloopy's Avatar
    Killa Cali
    look on the front of the block. right by where it would bolt to the transmission, there should be a flat surface about 1.3" by 1.5". on that surface, you should find numbers and letters stamped. those numbers/letters are the engine code which then tells you what engine it is and then the serial # of that particular block. like on this picture, the engine code is in the lower left corner.
    Quote Originally Posted by TWOLOUDNPROUD
    Mar 2007
    Toronto, ON
    Ok cool. that makes it a lot easier. What engines am I looking for to swap into an 88 Accord 4-dr? (now it has the stock carbed motor- A20A1??). I'm looking for a relatively easy & cheap swap to get the best performance.
    Thanks.
    shepherd79's Avatar
    Falling Waters, WV USA
    nothing will swap without major modifications unless for some majocal reason your shop has JDM 3G accord B20A motor.
    anything else will require custom everything.
    Killa Cali
    Quote Originally Posted by musclecarboy
    Thanks.
    how cheap and how easy do you mean? i suggest you start off in these places:
    https://www.3geez.com/forum/showthread.php?t=413
    https://www.3geez.com/forum/showthread.php?t=59141
    https://www.3geez.com/forum/showthread.php?t=51616
    https://www.3geez.com/forum/showthread.php?t=46299
    https://www.3geez.com/forum/showthread.php?t=38571
  1. Replies: 2
    Last Post: 08-04-2010, 01:20 AM
  2. Engine model or whatever...
    By Xtreemjedi in forum 3geez Accords
    Last Post: 08-28-2006, 07:11 AM
  3. '88 engine in a '86 model???
    By Cygnus in forum 3geez Accords
    Last Post: 10-05-2004, 11:44 AM
  4. Engine Model
    By 87_2LSi_au in forum Classic Honda Community Chat
    Last Post: 04-22-2003, 05:50 PM
  5. Locating the engine model #
    By kak in forum 3geez Accords
    Last Post: 01-27-2003, 04:43 PM
