My '82 1.6 auto has carb trouble & the Keihin 22/28 carb has been removed & partially stripped for inspection. 2 glasses of red wine came in very helpful when stripping it as before I just looked at the thing contemplating leaving it to another day.
Anyway it was straightforward enough & I have a reasonable idea with whats up with it... I think. The gasket between the 2 chambers had disintegrated, however I'm not sure that would cause any real running problems... The float chamber has a little gunge/corrosion at the very bottom & could very likely contribute to fouled up jets - which is essentially what the running faults indicate to (the mixture was running rich too)... car was difficult to start, cutting out at idle & when increasing throttle, but ran fine on fast throttle. It ultimately broke down & had to be recovered by tow truck.
To cure I'm going to clean up the float chamber as best I can & gonna get the jets blown thru. I've got a gasket set on order too. Then its a case of putting it back together & taking it from there.
Another option would be to replace the carb. Obviously Webers have been tried & tested so thats an option. However I've got a spare 32/34 carb off a '85 1.8 Accord auto which is in excellent condition. It looks virtually identical & would fit but is this a good idea & what would it been for fuel consumption/performance & all that?
In the manuals it makes mention of Venturi diameters. I dunno what these are TBH but for the 1.6 they are for the primary 0.866 in (22mm) & secondary 1.102 in (28mm)... then for the 1.8 they are...1.26 in (32mm) & ... 1.34 in (34mm). Does this mean anything to anyone?
There are no carb shops in my locale as far as I'm aware, I trawled thru the internet & phone directory & made a few calls without success.
So your help would be much appreciated!
