Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 114
Thread: PICS!!Look what came in the mail today:)
  1. #51
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    Re: PICS!!Look what came in the mail today:)
    Quote Originally Posted by twhonza
    Well thats what i told the shop...but aparently he cant resurface them because it has slots on them. I just got 4 new falken tires yesterday including the balance with an alignment..so now i know its really the rotters
    any rotor can be resurfaced! I had my AEM rotors redone and they are x drilled and slotted no probs. All they have to do is not be dumb and set the tip to go deep into the rotor. It just takes a couple of more light steps.
    take em somewhere else.
    machine shop maybe if none of the automotive shops have the common sense to do it.
  2. #52
    LXi User oldschool3g's Avatar
    1989/Honda/Accord LXI HATCH
    somewhere in cali
    yeah im gonna take it elsewhere...cause im not just gonna toss those rotters...theve been great to me. i guess ill have my uncle resurface them in cali when i go on the 25th of this month...im in arizona right now and it is F'in HOT!..lol
  3. #53
    2ndGenGuy
    Guest
    Another tip when braking: avoid complete stops when hard braking. Don't fly up to a stop light, and slam on the brakes. When you heat them up, then completely stop with the rotors not moving, the heat will cause the pads to deposit materials in that one spot. It will make your brakes feel warped when stopping.
    It's like when taking a freeway offramp, slow down way early, and let your car slowly come to a stop so the rotors can cool before completely stopping.
    You can actually try heat cycling your brakes a few times, sometimes that will take care of the problem. It doesn't cost you anything, and if they're still shuddering, get them resurfaced.
    Just get on an open road and run up to about 80, and do some threshold braking down to about 30-40mph. Don't lock them up or you will deposit more material on the rotors. Do it about 3 or 4 times, or until you feel brake fade. Don't brake much more if they start fading, then drive around a bit and let them cool. You may be surprised at how much smoother the braking may be. It usually burns off the deposits.
  4. #54
    somewhere in cali
    cool..thanks for the advise
  5. #55
    May 2007
    tennessee
    Yeah I have probs with my rotors too.
    Which muffler is that? Is it this one http://store.summitracing.com/partde...5&autoview=sku?
  6. #56
    somewhere in cali
    Quote Originally Posted by Hans
    thats not the muffler...thats the cat..but yeah, thats the cat i got
  7. #57
    May 2007
    tennessee
    Ah I meant to say cat not muffler lol
    That's the cat I'll be getting
  8. #58
    somewhere in cali
    lol... hopefully i get a good sound out of this setup...im anxious to see how it turns out...knightrider should be done sometime today
  9. #59
    May 2007
    tennessee
    Sweet man, congrats. I like knightrider a lot! Mabye... no you should def post a video of your car and rev it for us.
  10. #60
    somewhere in cali
    Smile Re: PICS!!Look what came in the mail today:)
    ok i will as soon as i get it back.
  11. #61
    somewhere in cali
    OK. just got my car back from the shop...everything was installed..turned the engine on and sounds pretty good..but idles really weird when i pull out it rattle like a moffo from underneath its slower, alittle loud, and the engine check light comes on and stays on? can anyone help me?
  12. #62
    May 2007
    tennessee
    Do a check all of the the fittings on the entire exhaust system, check the vacuum system fittings, check the gaskets and their fit on the head. That's all I can think of at the moment. They only installed the header, cat, muffler, and did custom pipes right?
  13. #63
    somewhere in cali
    Well heres exactly what was done: They installed the pacessetter headers connected to magnaflow cat 2.25" pipe to the muffler. then they intalled my NGK iridium spark plugs/wires...complete tune up with cap and rotor, fuel filter, oil filter, oil change, and some reconditioned injectors that i had bought.
  14. #64
    May 2007
    tennessee
    It could be the injectors or the spark plugs and or wires. IDK for sure though and the rattle is prob from them not putting the rubber bushings on the exhaust hangers or the exhaust being to close to a body panel.
  15. #65
    sounds like it could be your O2 sensors....did they replace them? also check your code.
    somewhere in cali
    well the spark plugs and wires are brand new. after test driving it for a bit i know that the rattling is the exhaust hitting something bad
  17. #67
    somewhere in cali
    no they didnt replace the O2 sensors...but one of them is new because a couple months ago it threw a sensor code so i had it replaced
  18. #68
    guaynabo89's Avatar
    FL
    swap your o2 plugs and check to see if its hitting a heatshield somewhere.
    as far as feling slower its because of the larger exhaust. itll most likely be faster in the upper rpm.
    do you have any other supporting mods?
  19. #69
    somewhere in cali
    Ok Ill tell them to swap the O2 sensors to see if it works. And your right about the rpms...when i hit the gas it seems to lag it...but once it hits higher rpms...it hauls some ass.
  20. #70
    the cat will take a week to fully break in....i remember mine being kinda loud and now its nice and deep tone to it. its easy to replace the O2 sensors...why pay some one to do it? plus they are cheap at like 30 bucks a pop...also did you seal the A/S part of the header.
    somewhere in cali
    Yeah im going to swap the sensors myself instead. I just took my car back to the shop right now...jacked it up with the big machine and noticed the the header is hitting the front fame member and the bracket that holds the downpipe wasnt installed right. there going to take a piece off the frame so it wont hit and fix the bracket...hopefully it will stop the noise...it was imbaracing driving it to the shop..lol..my car sounds like i have a bunch of soda cans hanging from the bottom of my car...lol.
  22. #72
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Try swaping the O2 plugs Left should be connected to the green plug, right to the white.
    CARDONE SUCKS.
  23. #73
    Idaho
    Where are the pictures of the header installed?
  24. #74
    somewhere in cali
    Quote Originally Posted by LX-incredible
    cool..ill check to see if thats how there installed when i get the car back later today. thanks
  25. #75
    somewhere in cali
    Dont worry bitesize...ill be posting plenty of pics later on today.
  1. Well i got a box in the mail today...
    By Tdurr in forum Classic Honda Community Chat
    Last Post: 03-27-2009, 12:52 PM
  2. look what came in the mail today
    By ghettogeddy in forum Classic Honda Community Chat
    Last Post: 06-07-2007, 05:30 PM
  3. My 89 Hatch LX-i pics today.....
    By BigDaddyJC in forum Classic Honda Pics & Videos
    Last Post: 04-16-2007, 05:21 AM
  4. yah! more goodies came in the mail today!!!
    Last Post: 09-03-2005, 10:52 AM
  5. Some new stuff I bought today .. 3 Pics
    By 89accordhb in forum Classic Honda Pics & Videos
    Last Post: 05-23-2002, 06:48 PM
