Results 1 to 7 of 7
Thread: question for you hi-mod guys...
    DX User wrxdriver99's Avatar
    May 2006
    1978 Honda civic, a20a3 conversion under cunstruction. my little girl will kick your ass.
    Medicine Hat, Alberta
    I have put an A20A3 5spd into my 78 civic, I am using a walbro 255 L/hr fuel pump with the stock fuel pressure regulator and stock wiring from the accord, except I have wired in a separate relay for the fuel pump.
    I'm having problems with the throttle after the engine warms up a bit. That is to say I can rev up the engine when its cold, for the first 2-3 mins, but then after it warms up, if I push the throttle it baffs out, doesn't stall out completly very easy though. To me it sounds like its starving for fuel, but I have a couple of questions.
    If I have the map sensor hose hooked up wrong(or any of the pollution control crap)will it do this??
    Has any one else swicthed to a racing fuel pump??? what problems did you have????
    Also I did try to check the service manual for the vacuum schematics, but all I found was for the A20A1.
    If more info needed just ask.
    Any help greatly appreciated.
    SXYCVIC
    1978 Honda Civic Hatch
    Nearly completed A20A3 swap
    ground up restoration/modification
    Will be White with blue pearle clearcoat
    http://ca.pg.photos.yahoo.com/ph/wrxdriver99/my_photos
    Re: question for you hi-mod guys...
    did you have to upgrade the return?
    I really don't know.
    i have a 255lph walbro and i never had issues with it, even with the stock fpr and wiring
    May 2006
    sort of. on the civic there was no factory return line, so I ran a new 3/8 fuel hose for supply and used the factory fuel supply line for a return. I have the fuel pump located under the car by the tank, because someone told me that it is a push style pump, not a pull, meaning it would burn out prematurely if it was located to far from the tank without a scavenger pump.
    >how would I know if the the fuel pressure regulator is working properly???
    I have an aftermarket one with a guage, I've just been too busy to put it on.
    I also just got an a/f meter, but the motor has two oxygen sensors, looks like one for each two cylinders.
    SXYCVIC
    you did eliminate the stock intank pump correct?
    May 2006
    yes, I'm using the original civic tank
    SXYCVIC
    LX User Estimated Prophet's Avatar
    Mar 2007
    88 LX-i Hatch MT
    Atlanta, Ga
    Any luck?
    Honda Parts Connection -- http://www.acurahondaparts.com
    D Series Army Dishonorable Discharge
    BT Defector
  1. another vr question, sorry guys
    By cody509 in forum Carburetor Tech
    Last Post: 09-15-2005, 12:57 AM
  2. Quick Question Guys....
    By XxDark_AccordxX in forum Interior & Exterior Care
    Last Post: 02-06-2004, 03:02 PM
  3. question for u guys...
    By bobsaccord in forum Classic Honda Community Chat
    Last Post: 12-01-2003, 11:53 PM
  4. question for amp guys
    By Neuspeed007 in forum Interior & Exterior Care
    Last Post: 08-27-2003, 02:55 AM
  5. Sad question for you guys
    By hondamanlxi in forum Classic Honda Community Chat
    Last Post: 07-15-2002, 03:05 PM
