Results 1 to 5 of 5
Thread: Door Latch Help Needed
    89LXi Honda Accord
    Northwest Arkansas
    When I try to open my door, it sticks. I have to pull on the lever several times to get it to finally un-latch. Has anyone has this problem before. How do I fix it?
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    I had a problem like that for my hood latch. It went away after I greased it and used it for a while (worked the grease into the latch). If the handle itself isn't moving smoothly pull it out and grease it. If the handle seems to be working ok it's probably the latch that needs the grease.
    Mike
    Jul 2002
    89 SEI Honda Accord
    Attending college in SC but actually from the U.S. Virgin Islands
    i think that the spring is messed up in mine.
    Canman. Reppin for the VI till the day I die.
    LXi User 88' Accord Ltd's Avatar
    89 EX-i, 91 Civic dx, 88 Civic dx
    Winnipeg Manitoba, Canada
    I had that problem on my old accord, i never got a chance to fix it though
    - Drive it like a Rental!
    My 89 Ex-i on Car Domain
    Nov 2000
    It is most likely an adjustment needed to the actuator rod that connects the door handle with the door latch. It is fairly easily adjustable, but you have to remove the inside door panel to get to it.
    I had to do a lot of adjusting to mine when someone attempted to break into the car by prying open the door below the door handle. In that case the actuator rod got bent just enough to prevent the handle from opening the door.
  1. Trunk Latch
    By 89accordlxigentyers in forum 3geez Accords
    Last Post: 02-26-2011, 10:27 AM
  2. Mot Fail!! Big Cost. Advice And Or Offers Needed! Steering Rack Needed!
    By ESDEEZ in forum Classic Honda Community Chat
    Last Post: 08-12-2007, 08:19 PM
  3. Replies: 2
    Last Post: 09-07-2004, 04:55 PM
