Results 1 to 5 of 5
Thread: Accord of the Month Nominations - June 2007
    87accordlxi's Avatar
    Oct 2000
    PLEASE TRY TO PROVIDE A MOD LIST OR LIST OF WORK DONE TO THE VEHICLE YOU ARE NOMINATING. PEOPLE ARE STARTING TO GET LAZY AND NOMINATING CARS THEY KNOW NOTHING ABOUT.
    Its time to nominate your favorite ride for AOM: June 2007
    Check out the Rules & Regulations
    How to Nominate a Vehicle for AOM
    All winners in the past year are ineligible for nomination:
    June 06 - WickedAccord
    July 06 - 88LXi68
    August 06 - Bullard123
    September 06 - Toneloc5145
    October 06 - Cheeseburger
    November 06 - TWOLOUDANDPROUD
    December 06 - mkymonkey
    January 07 - thegreatdane
    February 07 - picopop
    March 07 - Versanick
    April 07 - 87AccordLXsdn
    May 07 - RobT5580
    Members must have 50 posts in order to nominate someone
    Duplicate nominations will be deleted
    Posts made that are not nominations will be deleted
    Invalid nominations will be deleted
    There is no need to second a nomination! If a nomination is valid, it will proceed to the voting stage automatically.
    - Joe
    Re: Accord of the Month Nominations - June 2007
    MessyHonda (his LX-i)
    Engine Specifications:
    Stock A20A3 with 142k
    Custom Adjustable Cam gear
    koyo High flow radiator
    Teg 90-93 red CAI
    MSD blaster 2 coil
    Crane 11mm red wires
    NGK v-power plugs
    4g map sensor
    Coming soon:
    Pacesetter Ceramic headers 4-2-1
    Bored out TB
    Drivetrain:
    5 speed manual
    new clutch at 113k
    Coming soon:
    Custom Short Shifter with poly bushings.
    Exhaust:
    Coming soon:
    Magnaflow high flow cat
    2.25inch pipe with magnaflow muffler.
    Suspension, wheels & tires:
    Front: EBC dimpled and sloted rotors with AEM pads
    15inch Fat fives
    Falken tires 512 195/60/15
    DC front strut bar
    Tokico struts
    Rear: Powerstop rotors with AEM pads
    SE-i SS brake lines
    SE-i rear disk conversion
    Justins rear sturt bar
    Coming soon:
    lowering springs
    poly bushings in the front
    Interior:
    Prelude 4ws steering wheel with leather wrap
    SE-i armrest
    SE-i cupholders
    JDM Map light(not installed)
    OEM foglight switch(not installed)
    coming soon:
    PP Guages with white face
    bezel
    newer shiftknob and boot
    OEM foglight switch
    Ice
    Pioneer Premier tape deck 35wx4
    Pioneer 6 cd changer
    kicker 6.5 fronts
    almani 6*9 rears
    audiobahn amp
    2 10 inch kickers
    Exterior:
    20% tint in the back 35% in the front.
    Sylvania Silverstar lights
    JDM corners
    coming soon:
    rear mud flaps
    4g spoiler
    Clear bumper lights
    LEDs in all the front.
    might take out all dents and paint it accord 07 color
    I nominate 89StockLXi!
    Mods: NONE.. Bone stock and proud! This car is sooooo clean.. not a ding, dimple, scratch, swirl, fade, or any kind of blemish on the entire thing. Garage kept under a car cover its entire life and always handwashed. Just hit a whopping 62,000 miles and looks like it just rolled off the show room floor.
    1991 Civic STD
    Arbutus, MD, Baby
    I nominate Catalyst. He doesn't have a lot of mods but his car is SO clean. His pics look they're from a magazine. It's definitely a good example of doing more with less, and proof that you don't have to spend a ton or work for a years on end to have a nice-looking classic Honda.
    Quote Originally Posted by Catalyst
    List of mods:
    -Cat back exhaust with 2.25 mandrel bent piping, and a magnaflow XL series muffler, no resonator.
    -Prime 15in 5 spoke aluminum alloy wheels
    -Kumho Ecsta Tires
    -Newly painted Hood, Headlight covers, grill, eyebrows, bumpers, trim, and other misc. parts.
    -Sounds System : Kenwood deck, 4 6in. Rockford Fosgate punch series component speakers.
    -8mm spark plug wires, with NGK V-power spark plugs.
    -Other than that, shes stock.
    Daily Drivers Done Right
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    I nominate Legend_master, a true pioneer. I don't think anyone on the board could get by without his knowledge and expertise.
    Mods list...where to start
    Engine
    1991 B18a bottom end
    Stock pistons bored .20 over
    ARP head and rod bolts
    Fully balanced/shot-peened and all parts were coated
    New GSR/R Fuel pump and water pump
    Lightened flywheel
    GSR head Milled just a little
    Cosmetic thin head gasket
    STR Cam gears
    AEBS intake manifold with stock GSR TB
    Ebay Megan racing header modified with a 2.5 Collector
    2.5" Pipeing all the way back to a vibrent Racing muffler.
    Suspension
    FRONT
    1. 89 LX-i hubs (must be 88-89 LX-i Hubs) with new bearing
    2. 11" Acura Legend rotors Redrilled to 4x100 from a 1989 Acura Legend
    3. 1998 Acura integra Type R Calipers (no bracket Required)
    4. Full Prothane Poly Bushings for the Lower control arm and OEM for the rest
    5. SS Steal braided brake lines all around
    6. ARP extended Wheel studs (just because I wanted to)
    7. Suspension Techniques 2.5" springs
    8. 1990 Honda accord Full Bodied D2 Racing Coilover Sytem
    9. Suspension Techniques front sway bar.
    10. 1988 Prelude 35/40 prop valve
    11. all ball joints and tie rod ends.
    12. Ingalls Camber Correction Kit
    13. EBC Brake pads
    REAR
    1. Sei Rear disk brake Convertion
    2. 1989 Acura Legend Rear Calipers (they have a bigger pistons)
    3. Drilled and slotted EBC rotors
    4. EBC green stuff brake pads
    5. Suspension Techniques rear sway bar
    6. Lower Poly shock bushings
    7. 1988 Honda Civic Full Bodied D2 Racing Coilover Sytem
    EXTERIOR
    88-89 Coupe Bumper
    Integra Front Lip
    Black Powder Coated Polished Lip Integra LS Wheels
    INTERIOR
    Removed Rear Seat
    '89 SE-i Coupe
    Awaiting Garage
  1. Accord of the Month Nominations - June
    Last Post: 05-13-2009, 12:11 PM
  2. Accord of the Month Nominations - June 2008
    Last Post: 05-14-2008, 07:39 PM
  3. Accord of the Month Nominations - June 06
    Last Post: 05-10-2006, 07:54 AM
  4. Nominations for Accord of the Month - June '05
    By NXRacer in forum Accord of the Month Archives
    Last Post: 05-20-2005, 09:21 AM
  5. Accord of the Month Nominations for June
    By Dibbs in forum Accord of the Month Archives
    Last Post: 05-10-2004, 12:12 PM
