How do I take out the cover on the rear speakers. I want to change them this evening.
Do I do this from the trunk or from inside the car?
thanks.
thanks.
from the trunk there shouyld be 4 8mm bolts i belive i could be wrong on the size then when u get the pods ou there is 3 or 4 philips screws
they are 4 10mm nuts...you can get them with a ratchet...then disconect the wires and push up the speaker...you might have to take a dremel to the covers since they are kinda small for most aftermarket rear speakers
thanks guys. Done!.
How do I remove the door speakers? I guess I have to remove the entire door panel?
no there should only be 3 screws around the bottom
I'll check that tomorrow.
thanks again.
the thing that sucks on those door speakers is i havent be able to find an aftermarket speaker that fits and mounts up like a stock one
my pionerres lined up fine
its cool id rather cut and mod the mounting bracket for better quality speakersOriginally Posted by teck
i used to have a set of pioneer 5.25s in the factory brackets and then i bought a set of 5.25 to 6.5 adapters that were more of 5.25 spacers, so i had to cut the inner part out to fit my 6.5s
If you dont want to mod the covers, get some covers from an SE-i. They are 6x9's.
the 88-89 lx-i also came with rear 6by9.
