that's just way too much money! at least, for me it is...
Prestone 100% radiator coolant: $20 for a couple jugs
6 quarts of B&M Full Synthetic Trickshift ATF fluid: $30
Valvoline Synthetic DOT4/5 brake fluid: $15 for a couple bottles
a) the radiator shop or dealer would NOT use synthetic tranny fluid... B&M Synthetic is far superior to any ATF. drain 3 quarts, refill, run car for about 5 minutes while on the jack stands... shifting from R to D4 a few times... then drain again and refill another 3 quarts. that will get your transmission about 75% full of new synthetic ATF
b) grab a friend to help you pump the brakes while you bleed the brake fluid valves on each wheel corner
c) learning how to flush your own fluids: priceless
had to make that lame joke
![Smilie](https://www.3geez.com/forum/images/smilies/smile.gif)
