If your rpms are fluctuating, thats a vacuum problem (not timing) check all your vacuum hoses and replace any cracked or worn hose, one by one or you'll be sorry. The temperature sending unit is located on the intake manifold (passenger side) there is a coolant hose for the manifold and right next to it on the inside is the sender unit (little tiny one) at the back of the carburator and under it. Its the second pic on the manual from the earlier post.
