Originally Posted by mikes87lude
comparing the HEI to the GM DIS or ford EDIS, i think the best part of the HEI is that it uses the sensors that are already on our cars. it requires very little work to actually get it to work, and no fabrication work. i havent researched the gm DIS or ford EDIS, but i believe they both use a wasted spark system, so the voltage on each of those sparks is split in half whereas with the HEI, you get one powerful spark each time.
the main reason why im going HEI is because its cosmetically 'in place'. the only thing i have to do is remove the weights, and lock the shafts together which is alot easier then modifying my car with a crank trigger which both the GM DIS and ford EDIS needs. i know ive got my crank pulley modded for EDIS already, and its easier to setup, but i wanna do HEI to 'inspire' people to do the same thing. its easier to get people to take apart their distributor then to take out their crank pulley, order a trigger wheel, and to have it machined on and welded.
as far as the B16 intake manifold goes, it gives you a better top end at the expense of the low end. for what im using this car for, its not a problem. although i havent actually ran the motor yet, i think its a little exaggerated. when we speed up in traffic, its our feet that control how fast we accelerate. when it comes to the drag strip, our feet are planted to the floor anyways, so we could use the better top end anyways.
i got robbed of my weekend because we 'needed' a sunday shift which i believe is totally BS. my foreman is on a temporary power trip since nobody really wanted to work on the weekend, so he dragged 5 of us into his office and tore us up new assholes. what he failed to realize is that ive been working for a different department for the past week or so, so obviously there was no work for me or anybody that helped me to do
