Page 12 of 23 FirstFirst ... 2891011121314151622 ... LastLast
Results 276 to 300 of 573
Thread: Frantik's Green Monster - Past, Present & Future
  1. #276
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    Re: Frantik's Green Monster - Past, Present & Future
    A couple of photo's of the block after I gave it a once over with hot water, simple green and Dwan dish soap.
  2. #277
    Feb 2012
    89/accord/lxi
    CF hood porn. hope you like it dirty lol ahhaha. It need some work but it was worth the $50 I paid for thanks to greedy.
    Spare tire sub from rsx. still need to place the amp in the stock sei location but other then that sound great.
  3. #278
    Feb 2012
    89/accord/lxi
    it's been a minute sense the last update. So here you go. I started the B16 it swap and I'm working in the obd1 swap this week should have it back up and running by the end of the weekend. Just missing a couple of parts for the itm like a fuel rail, iacv(think I have just misplaced it) and a TB gasket.
  4. #279
    Feb 2012
    89/accord/lxi
    Obd1 swap done. Now to work on getting it to run better. I'll take photos of it tomorrow.
  5. #280
    top work! havent checked this thread in a while.
  6. #281
    Got it running properly?
  7. #282
    Feb 2012
    89/accord/lxi
    Now your asking to much. I also did the B16 itm so I need to work on it falling flat on its face. It's almost as if the firing order is wrong or its 180 off
  8. #283
    carotman's Avatar
    Montreal South Shore
    If you use the B16 throttle body, check the idle adjustment screw. I had to enlarge the hole behind it on mine. It was really too small for the engine to idle properly.
    I need these parts!
  9. #284
    Feb 2012
    89/accord/lxi
    Well its almost as if the firing order is wrong. And yes I'm using the stock b16 tb but it's on a skunk 2 pro itm 😎. I also still need to extend the wires for the intake temp and iacv
  10. #285
    Feb 2012
    89/accord/lxi
    Photos or it didn't happen. I'll post I video for you guys soon. I need to replace the o-rings on my injectors because I have a leaky one and I wanted want to start a fire.
  11. #286
    Feb 2012
    89/accord/lxi
    Here's the Video of the first start. Still need to do a couple of things like hook up the iacv, itm temp and chip my ecu.
    obd1 swapped 3geez - YouTube
  12. #287
    LXi User 79cord's Avatar
    Melb, Aust.
    Congratulations!
  13. #288
    Feb 2012
    89/accord/lxi
    Thanks man. It's still fat from done but it's headed in the right direction.
  14. #289
    Feb 2012
    89/accord/lxi
    Stock b16 injectors clean up and the 450cc DSM injector upgrade for the turbo kit. So close but so far.
  15. #290
    SEi User obdriver6's Avatar
    Nov 2008
    1989 Accord LX-I Coupe
    Las Vegas, NV
    Glad to see its coming along.
    1989 Honda Accord LX-I 300K+
    Build Thread
  16. #291
    i always mix you 2 up with your usernames
  17. #292
    ^^ truth
  18. #293
    Nov 2008
    Las Vegas, NV
    It also doesn't help that both our cars are green too lol
    Build Thread
  19. #294
    Feb 2012
    89/accord/lxi
    It's because I want to be you so bad I had to steal everything you use to make people think I'm you. Lol ahahhahaha
  20. #295
    Nov 2008
    Las Vegas, NV
    Hmmm I don't know if I should feel flattered or scared lol
    Build Thread
  21. #296
    If you're using the OE injectors, it's most likely the injector itself failing. They start leaking from the case and it looks like an oring leak.
  22. #297
    Feb 2012
    89/accord/lxi
    It was the oring. I ripped it. Lol
  23. #298
    Feb 2012
    89/accord/lxi
    Just a bit of a up date guy's. I'm sure most of you guys seen the post I started for the cjs wiring harness. If not here's a https://www.3geez.com/forum/showthread.php?t=111236 . This weekend I started and finished laying out a stock harness for a jig. Next I'll be putting my stock motor some what back together so I use it as a test fit. I'm hoping get this done and the car running for a race event march 1st. Fingers crossed thjs is the first time I've done anything like this.
  24. #299
    carotman's Avatar
    Nice work with the jig
    I need these parts!
  25. #300
    Feb 2012
    89/accord/lxi
    Thanks man. I'm Putting in some really serious work. I told him I would take care of her and that I would finish what he started.
  1. The green monster is back on the road w00t
    By frantik in forum Classic Honda Pics & Videos
    Last Post: 04-22-2011, 10:49 AM
  2. Green Machines Green Hatch!!!!
    Last Post: 02-07-2003, 10:58 PM
