Page 20 of 23 FirstFirst ... 101617181920212223 LastLast
Results 476 to 500 of 571
Thread: Frantik's Green Monster - Past, Present & Future
  1. #476
    Re: Frantik's Green Monster - Past, Present & Future
    Thats some awful thick steel there
  2. #477
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Before and after
    That coil bracket is nice. I'm going to have to get me one. Awesome updates the project is moving fast nice work
  3. #478
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    Part's....
    Getting closer with each delivery.
    Funny how close BobaFett's parts fit the part I have already it's like it was meant to be
  4. #479
    Feb 2012
    89/accord/lxi
    Taking small bite's
  5. #480
    /like
  6. #481
    Feb 2012
    89/accord/lxi
    Fake it tell you make its right
  7. #482
    Feb 2012
    89/accord/lxi
    Getting warm. Definitely clocked the turbo after the photo but gonna need a 90 off the turbo for the oil return to clear the front mount. Gonna cut and modify the hood latch. Intercooler hanging a bit low so got to get more bends to see if I can get better fitment. Down pipe needs be redone because it turns to far forward so it would hit the stock cross member or I can to a traction bar to get even more space and probably make more room for the oil return line.🪛
  8. #483
    Feb 2012
    89/accord/lxi
    Couple more shots from this morning. We'll it's obviously thing's still need to be cut to fit but this should give you idea of what I'm looking at as far was work go's. Got a couple more pic's coming
  9. #484
    Feb 2012
    89/accord/lxi
    The last of them
  10. #485
    So will you be the first guy to run the Mossulman manifold after all these years?
  11. #486
    Feb 2012
    89/accord/lxi
    Lol naw there are a handful of people on the FB that have been running them. Some but most of them have been sitting. At least two are carbd and one is FI but has been taken off due to the chassis falling apart around it. There is a guy running one on a 2g lude but it was modified to run a external wastegate and up pipes. There's been plenty of stop start and sell offs over there since the group buy and there is a even a turbo a series/3geez group now in days. If your not part of both you'll miss something. I will say no one is pushing a boosted a series out said of Jeremy right now tho not even close to his build. But that's a race car all the other are street dd or long trem projects
  12. #487
    Feb 2012
    89/accord/lxi
    At least the first 4 I could find most of which have happened with in the last 3 years if not longer 3 or of 4 are still "running" the one that's not in Shane's but he's trying get his chassis right and he's been doing a lot of great work making plug and play harness opinions for the 3geez community one of which I'll probably be running in my car. S/O to him for saving my build after I got fucked no Vaseline by a og member on the original harness I had planned. None the less progress is being made not only with my build but a handful of other a builds as well
  13. #488
    89T's Avatar
    Apr 2004
    It's a street car that tracks sometimes.
    Sent from my SM-G981U using Tapatalk
    un-motivated!
    3GR
  14. #489
    Good god, that one guy decided to go bike carbs and turbo. I am sure that car has an attitude.
  15. #490
    Feb 2012
    89/accord/lxi
    I wish he'd post a video but I don't thing it's road worthy tbh.
  16. #491
    A real glutton for punishment type.
  17. #492
    Feb 2012
    89/accord/lxi
    Picked up some parts at the pepboys closing sell today. Swap out the 2.5in pipe for 3in. I already have a 3in vband so I'll probably weld it to the tb and the 90 off it. Then weld the straight to the 90 so it all one piece. Obviously I'll have to cut the 2.5 90 pieces near the radiator support area that go's to the IC but this fit us better then before. Not not totally sure I'm gonna leave it like but will see. I also I'll have cut the bov off the 2.5 straight and weld it to the 3in but yeah there's that. Picked up a 3in Muffler as well if I ever make it that far back with my exhaust
  18. #493
    Feb 2012
    89/accord/lxi
    Change my mind on the ic sooo use you imagine that I have the side ic the I ordered that was meant for a dsm. But this will cleaning things up a bit and overall fitment is way better then way. Way shorter pipe run and more space for activities.
    Aluminum 2.5"I/O 1 SIDE Front Mount Intercooler 24"x11"x3" for EclIpse Talon DSM | eBay
  19. #494
    Feb 2012
    89/accord/lxi
    But why stop there got some time mount my msd coil packs to the cop mount as well. Slowly but surely getting there. Forward progress is progress whether its slow or not.
  20. #495
    You read my mind, I was really thinking you could really benefit from a same side intercooler! Man, those things are expensive to buy new though.
  21. #496
    Feb 2012
    89/accord/lxi
    Yeah the one I want it $1k or more but this $140 one on ebay I post the link to should do the trick. Hell it was make for a dsm/Eagle Talon/Mitsubishi Eclipse so I should be good to 400ish hp which is more them my goal. So for under $150 my expectation is that it will fit based of the size Dimensions listed and I'm sure I'll have to cut the inlets off to put the v-bands I pick up and add 90s off the ic to make it easier to turn flex the pipes into the bay. The dimensions list as being about the width of my tucked radiator it's about 3.5in thick so I'll have to cut the bumper some to fit it and the 11in height sits in the 14.5in height area thats available. I do for see I'll have to trim some the radiator support area on the side and bottom but it's then sheet metal so it would be to hard to take a grinder to it when the time comes to do so.
  22. #497
    Feb 2012
    89/accord/lxi
    So I know some were considered with the hood closing looks OK me minus the fact there is not Lach at the moment lol ahahah one hurdle at a time lol
  23. #498
    Feb 2012
    89/accord/lxi
    New intercooler cam in as the site went down so here's a quick update
  24. #499
    Feb 2012
    89/accord/lxi
    No more water pipe for me
  25. #500
    Feb 2012
    89/accord/lxi
    Cut some stuff with my grinder to make room much better. Still have to figure out how I'm gonna to mount/bolt them in place but at this point it if fits it ships.
  1. The green monster is back on the road w00t
    By frantik in forum Classic Honda Pics & Videos
    Last Post: 04-22-2011, 10:49 AM
  2. Green Machines Green Hatch!!!!
    Last Post: 02-07-2003, 10:58 PM
