Results 1 to 7 of 7
Thread: Need serious help! This is p1$$1ng me off
    LXi User 1989se-i's Avatar
    89 Accord SE-i Coupe
    Jokelahoma
    This sucks. I bought a new headlight assembly, cause my other one was f***ed. I put the thing in, and none of the holes line up very well. I put in 1 screw, and the other holes were about 1.5"-2" above their holes... I managed to get it eventually, although not very well. Now my headlights is totally misaligned.
    Its recessed about an inch, and its not center, its closer to the center of the hood, which i cant shut, cause itll smash the headlight. When i pop them up, it points at the ground about 5 feet from the car, and the other onse is aimed correctly....
    What the *bleep*in *bleep* should i *bleep*in do?!?!
    HEELLLPP!! Ahhhh!!!!!!!
    Performance Modz: Short Ram Air Intake, Custom Exhaust w/o Cat & Resonator, Cherry Bomb Turbo Muffler, Accel Coil, Removed AC
    Other Modz: Clear Blinkers, Purple Calipers, Accord Emblem On Dash, Winking Headlights
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Your frame is probably not straight (accident??)
    Sorry can't help you with body work.
    Jokelahoma
    Damnit!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Jokelahoma
    Someone? Anyone..?
    LX User flamed89's Avatar
    89 accord LX-i 88 accord lx 93 teg 4-dr
    maryland
    if you wrecked your car then your core support is bent. If thats not the case the frame of the headlight assy is fucked.also there are little shims under the mounting points did you put them back?
    Jokelahoma
    Shims? Mounting points?:-/
    LXi User 88' Accord Ltd's Avatar
    89 EX-i, 91 Civic dx, 88 Civic dx
    Winnipeg Manitoba, Canada
    shims are kinda like washers but itll move the bracket that holds the assembly up to wim it properly. I have a shit load in my car, im going to build custom brackets but thats not the point. The mounting points are simply where the bracket bolts into the frame.
    - Drive it like a Rental!
    My 89 Ex-i on Car Domain
