Code:
HERE IS A LIST OF THINGS YOU MIGHT TAKE A LOOK AT
Check for Vacuum leaks
- Intake Manifold Gasket
- Vacuum lines
- Gaskets Carb/EFI
- PCV Valve
Check your oil system
- Oil Level
- Oil Filter
- Oil Weight
Check the coolant system
- Radiator Fluid Level
- Thermostat
- Fans / Thermoswitch / Coolant Temp Sensor
- Waterpump
- Check your engine temperature
- Does the engine heat up to normal operating temp?
- Does the engine overheat?
Check Ignition
- Plugs
- Wires
- Ground Wires ( Battery / thermostat / radiator support )
- Cap / Rotor
- Ignition Timing
Check ECU
Check Fuel System / A/F Mixture
- Float Level (Carb)
- Injectors (EFI)
- Pressure Regulator (EFI)
- Fuel Filters
- Fuel Pump
- AS Valve (Carb)
- A/F Screw (Carb)
- Cut-Off Solenoid (Carb)
Emissions System
- O2 Sensor
- EGR Valve
- Catalytic Convertor
Methods to help reduce NOX , HC ( Hydrocarbons ) , CO ( Carbon Monoxide )
:KEY:
#) Solution
--- Problem it addresses
-- More Related Solutions
0) Ignition Sytem . make sure it's working properly
--- High
HC from poor ignition
1) Retard ignition timing to give more combustion time
--- High
HC from incomplete combustion
2) Compression , Compression Ratio , Fuel Octane
--- High
HC from poor compression
-- Change Fuel Octane
-- Check Engine Compression
3) LEAN A/F mixture to increase engine temp
--- High
HC from lean mixture
4) RICH A/F mixture to decrease engine temp
--- This may increase
HC or CO
--- High
CO from a rich mixture
--- Too Rich a mixture can melt the Cat
5) EGR
NOX reduced by the EGR
--- EGR lowers the combustion temperature
High NoX is usually directly related to the EGR. Very common on the 4th gens since the EGR ports get clogged very easily. I'm not sure if it will harshly change other readings though. Probably want to hook it up again to be safe.
- Clogged EGR passage
If your high flow cat is a "real" good quality high flow cat, then in most cases I've seen, it should get lower readings than the original cat. If it's just a test pipe or a cheaply made CC, then that might be your cause. Could also be your O2 sensor.
- O2 Sensor
If I have trouble passing emissions here in BC, I usually get high octane gas, dump some more octane booster in it, retard the timing, make sure the car is tuned up, and drive the car atleast 30 minutes on the freeway or something before going to testing.
- Octane
