When ever I accelerate, the speedometer needle shakes up and down as it's going up. The needle still accurately indicates my speed, but it just shakes under acceleration. Anything that I can do to fix it?
A new speedometer cable might help. If you replace it, and it still shakes, I think you'd have to have the speedometer rebuilt. Get an OEM cable though. I picked up a cable at the auto parts store, and while it fit, it was about 2 feet too long and wound up binding up and it was awful.
I have cured those by greasing the cable at the end(s)
Otherwise this is a charactoristc of these cars to an extent
One thing you can try that might work for a little while is to pull the inner cable (has to be pulled from the transmission end) and lube it with white lithium grease. That worked for me for a couple of years. Eventually I just replaced the whole cable.
Okay thanks. Ill try greasing the end and if that doesn't work I'll prob just leave it cause it's more of a small annoyance rather than a big problem.
You actually pull the entire inner cable out from the transmission end and grease it down the entire length. Now that I recall, mine was actually noisy on cold days. The bouncing needle may be caused by wear on the inside of the cable jacket so your only option may be to replace it. I got mine for about $35 at hondaautomotiveparts.com.
mine makes a clicking noise in the dash and its about 10 kms faster than the car is going
give er balls until she stalls...then gas er up again!
it also shakes
Originally Posted by DBMaster
Mine does the same thing, DBMaster hit the hammer on the nail. You have to grease the entire cable. I believe there is some kinds of cover you have to remove as well.
