Here is my $30.00 Project car. 1989 Accord DX. Had a seized motor. I am starting the tear down right now. Building a whole new engine for it.
cool! $30, cant beat that loland
to the forum
are u staying carbed or going fi im also in the procees of rebuilding a motor my lx is going fi i have a thread started with pics of my progress and theres some helpful info in there form some of the vet members
Should have saved your money.
Just kidding! I like DXs, too. They're already stripped so you don't have to do it.
Welcome to the forum.
Do a F.I swap while you have the engine out. you'll be happy you did![]()
nice clean car....like everyone else said do the fuel injection swap. also what are the specs that you are going to build your motor with?
$30 for a car = good deal. Welcome to 3geez. It sucks that the engine is seized, but it will be fun to rebuild an engine. You came to the perfect spot for that
Very nice project.
It's almost like you have a blank canvas. Use your brush wisely
Thanks for the welcomes to the group. Here is the short and dirty on the car. Never been wrecked, Only rust is the lower rocker on the drivers side from sitting parked outside for 3 years. Left front coil spring is broke. Interior was clean. Pulled the interior to inspect fuel and brake lines under carpet. I have been considering the FI Swap. Found a few complete needs lists for the FI Swap here already. Harness, ECU, and other tid bits. My new short block is bored 20 over. Should be here next week. Have the new head sitting and waiting. I would like to do the Si rear disc swap. Hard to find all the parts right now. Pretty clean slate as it sits.
Also to speedpenguin's post...Had a 91 Eclipse..I actually miss it..Lost it in Hurricane Katrina. guess she had an appetite for DSM's..LOL Also had an 85 Tercel 2 door Hatch that I converted to AWD SR5 with the 6 speed Manual..Fun ride...Also Ate up by Katrina...Now I am back with my clean slate 3G.
nice find for 30$ good luck andOriginally Posted by Nemisis
hi
Welcome to the group![]()
Quick Update. The new head is in. Should have the block in a week. Gonna finish pulling the Old Trans and Block this week.[IMG][/IMG]
Where is the DIY Thread for the FI conversion from the Carb DX setup? Need a complete pull list when I go to the salvage yard Friday.
fyi the rear discs come from an SE-i not an Si
that is one of the most harder jobs to pull off....if you have the mechanical expirience i would go ahead and do it. also look at the condition of the car. i found a good deal on a fuel injected car...and at the end it was cheaper than trying to convert my old carb into fuel injected cuz there is no warranty
> EFI AlternatorOriginally Posted by Nemisis
> Atmospheric pressure sensor (located under the heater blower)
> Cabin wire harness
> Coolant splitter (located at the very corner of the
> Distributor (you also need the bolts)
> ECU
> EGR Pipe (with the gasket)
> Engine bay wire harness
> Exhaust manifold (88-89 only)
> Fuel feed line (the one that connects to the fuel filter)
> Fuel filter assembly (near the vaccum control box)
> Fuel pump
> Injector resistor box (located near the right strut tower)
> Intake manifold holder bracket
> Oxygen sensor (88-89 only)
> PGM-Fi intake manifold: This includes the injectors and all the sensors
> PGM-Fi Vacuum control box and charcoal canister
> Main relay (located under the dash on the driver side on the side wall)
> Metal coolant pipe (under the intake manifold)
> Thermostat assembly
> EFI Throttle Cable
Thanks for the 411. Yes I meant to source SEi..not Si. I have my list now for the scavenger hunt. I will post the results of the finds over the weekend.
hey man nice find i got myself a DX also and im going to be starting a HUGE project in a month or so here. im doing the legend v6 into the accord....sleeper....
wish me luck anyone on here with ANY info on this swap can contact me
dave
88 accord dx at the jyard
have fun with that one and post picsOriginally Posted by daves88coupe
I saw a V6 into a MR2 post somewhere awhile back. Not on these forums though. Back to my Scavange hunt for the weekend..Will post the finds.
