As i sit currently i have a A20A1 with new timing done, new alt. a recent tune up and a new set of wires and plugs as well as a coil cause the idiots who did the timing broke it. :end rant:
I was wondering if it's possible to reach 200hp and 200ft-lb with the following
Weber Carb Not sure which one (need to be schooled)
Pacesetter header
Custom Exhaust (already have it.)
Complelte engine overhaul (or get a new one from IPP) Depends on $$$
new A20a1 or a3's are $1123
Water pump
Valvetrain (valves, springs, seals)
Pacesetter short throw shifter
Trans Cooler
Oil Cooler
Oil Pump
MSD Or Accel Ignition system
Fuel Pump (walbro?)
head work (port matching)
bore block .20 over
custom .20 pistoms not sure what C/R i would run.
camshaft grind stage 1 (paeco power band around 2,500+)
if possible a pulley set.
torque
prelude/integra hybrid tranny
lightened flywheel
New clutch have not picked a brand to many choices.
