88accordlxcarb
The charging(Battery) light in my 88 LX has been doing weird stuff. IT started initially when i turned the car on(it was warm, and just driven 20ish mins) and the light stayed on. I tested the alternator with a multimeter and it read around 12.50, so it was not charging.
Later, as i was driving i noticed when i would sit at idle the light would go off, and when i would accelerate the light would come back on. Then it will stay off for maybe even a day at a time, then come back on. Sometimes it comes on when i start the car, sometimes not.
I do have an aftermarket amp and sub. When i had the multimeter on, and no light on, the battery read around 13.08, when i would turn the radio off, it would go to 14.34ish.
Is this the alternator? I checked fuses, they are good, and if i knew where the grounds were i would check them. I also had it tested at advance. All the guy said was "the diode was good, 49 amps, 14.45v". This of course was when the light was off...
