Results 1 to 15 of 15
Thread: ECT...??
    2.0Si User 88LXiHB's Avatar
    A moneypit!
    Vegas, baby!
    ECT...??
    My ECU is telling me that I have a bad ECT sensor (Engine coolant Temperature). My question is: Would a bad ECT make my car run bad? cause it sounds like it would just give bad readings to my temp gauge or something...
    My car has what I thought was a fuel problem, it studders on accelleration, has a bad idle, when I blip the throttle the RPMS will drop, when I'm pushing in the clutch to stop, my RPMs will just fall all the way to zero, and then it will either die, or idle bad for like a split second, then bounce right back up to 1K. All of these problems happen often, but not all the time, thats what I dont get...
    Could my bad ECT be causing all of this??
    Oh yeah, where is my ECT...
    Damnit, I'm a DX user AGAIN Marc!!!!
    The GSX was killed, I need something new...
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    What is an ECT?
    Alex
    A moneypit!
    Vegas, baby!
    I edited my post...
    was an 89 coupe Lxi, but now is an 89 dodge colt hatch with a GST under the hood :)
    Valley Stream, NY
    yea ur ECT sensor could be doing that....eventually its gonna get bad enuf to the point where the car wont start anymore after its warmed up. The problem is once the check engine light comes on for that sensor, the engine goes into limp mode, which is full rich and retards the ignition for safety. My car used to have that problem...it smoked a lot on hard acceleration (too much gas) backfired on shifts, or just letting up on the gas with it still in gear....once u change the sensor..the car will run like new.....and DAMMIT...im a DX user again too....argh...
    There are 3 things that are most important in life....eating, sleeping, and racing.
    A moneypit!
    Vegas, baby!
    You just described some more problems I'm having, I think this is my problem. I just found out last night that I painted over my check engine light by accident, and havent seen it for about 3 months(I AM retarded ) , thats why I figured it was a fuel problem.
    Does anyone know where it is located on the car, and where I could get a new one??
    LXi User DarknessRS's Avatar
    Aug 2000
    2010 Genesis Coupe; 1996 240SX
    Sacramento, CA
    Here it is:
    2010.01.01
    Pics of the '89 Accord Coupe: link
    Aug 2000
    Sacramento, CA
    And another
    2010.01.01
    A moneypit!
    Vegas, baby!
    I put in my new ECT today, fixed my idle problem kinda, still idles low, but woun't drop all the way to "0" and/or die anymore...
    My first gear feels strong, my second gear still has a kind of pause before full power (PRETEC? ), and my third, fourth, and fith gears still feel like they're "bogging down" under hard acceleration...
    Aug 2000
    Sacramento, CA
    Hmm, well try some simple stuff like changing your air filter. It also might be a problem with your fuel injectors. Try some of that fuel injector cleaner additive stuff.
    2010.01.01
    carotman's Avatar
    Montreal South Shore
    If it was running rich for a long time, that engine might be dirty.
    Like DarknessRS said, try that Injector cleaner.
    I need these parts!
    LX User 3rdgenSLIMER's Avatar
    1989 Honda Accord Lxi
    Longview, Texas
    hey darkness..........where did you get those pictures??? cause if it was in a book for our cars, i wanna know where to get it.
    1989 honda accord lx-i. APPEARANCE: 17" eagle alloy racing rims series 169. onsoku racing coilovers for a 90 accord, suicide trunk, green LED undercarraige kit (scans, strobes, beats to music, and solid), 1 20" green lava tube, 3 20" green neons, 2 9" mini green neons, 1 15" lightining rod, 1 10" green neon, neon green racing pedals, 2 green interior strobes, set of headlight strobes in trunk, 1 15" tourquoise in trunk, green LED windshield squirters, reverse indiglo gauges. PERFORMANCE: J-SPEC A18 ENGINE, stage 1 clutchmaster clutch, tenzo r muffler, 2 1/4" piping, custom cold air intake, with ractive filter. AUDIO: jvc kamelion cd player, jenson 6x9's, jenson 6 1/2's
    **The 3rd Gen formally known as radioactiveaccord/weetoddedd**
    Aug 2000
    Sacramento, CA
    Those pictures are out of the 1989 Honda Accord Service Manual. Back when it was new, it was $80. There is also a Hayes brand manual for the car. I don't know what either book goes for now.
    2010.01.01
    Aug 2001
    1988 Accord DX 5spd
    Dayton, OH
    Is the ECT only on EFI models? The problems 88LXiHB had are kinda like mine. But I have a carb
    I don't have a carb, but the chilton's shows an ect in their carb wiring diagram. Could be wrong. What I want to add, has nothing to do with the ect. I broke fan sensor "b", between the bleed screw & the ect, while changing my ect, D'oh! When I replaced it, my left fan began running along with the right! Before it only ran when the a/c was on. Also, now the left fan also runs after the car is shut off for about 20 min. I'm guessing! Thought it was worth mentiong, in case any 1 has those symptoms. I hadn't see any thing mentioned about it before, and was planning on grabbing a fan control at the "yard"! :smokin:
    Aug 2000
    Sacramento, CA
    The carbureted engine also has an engine coolant sensor, but it is located in a different place.
    2010.01.01
