Page 4 of 20 FirstFirst 1234567814 ... LastLast
Results 76 to 100 of 490
Thread: thegreatdanes Aerodeck restoration project
  1. #76
    Re: thegreatdanes Aerodeck restoration project
    that is just so damn awesome!!!!
  2. #77
    speechless, so ^^^^ ditto
    well said A18A
  3. #78
    x2!
    Can't wait to see its done!!
    looking good!
  5. #80
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    Thanks alot guys!
    Quote Originally Posted by Tomisimo View Post
    NiiiiCe...
    The Great Work. I have suggestion to U my friend... LoL
    Why dont You shave side moldings while you at it with a body. or You want to keep it stock? all round.?
    I dont want to keep it stock, but I'm not going to shave the sidemouldings. It's a huge task to weld them shut and I'm afraid I wouldnt be able to make both sides symmetric.
    That's awesome work!!
    This is a really nice restauration project! I know that front lower radiator support can rust to pieces. Mist have been a pain to drill all those spot welds.
    Oh, don't forget to make that square hole in the back for the bumper support. You only have the bottom one now since you rewelded new sheets of metal.
    Thats a very sharp observation I didnt make them yet because I couldnt decide if I should trust my measurements of where it should be or wait untill I can line it up together with the bumper. But I think it's mostly because I was lazy.. I've marked up where the holes are supposed to be according to my measurements though.
    Yea those spotwelds takes a while to drill out.
    looking great.
    how log do you think its gonna take u to completely finish?
    I would like to get it done this year, but it wouldnt surprise me if it takes longer.
    Link to my 3geez garage
  6. #81
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Quote Originally Posted by thegreadane
    I agree with You on this one, not least those panels are wary thin, like 0.6 mm if not less than that. I'll probably gona remake mine. dnt really satisfied with my work.
    About the engine, did You rebuild it at the same time as You work on the body or? I bet it going to look like ShowItem. all shiny and new.
    Well. Keep on doing so You'll get it on the road this year
    My Build Thread
  7. #82
    wow looks really great
  8. #83
    Jan 2003
    Denmark/Europe
    Hopefully but not likely hehe. Yes that's right I even forgot about the thin panels, you run a risk of warping the panels horribly, which then will require loads of bondo to make them straight again, and I dont like bondo...
    Did you weld yours?
    The old A20A3 engine wont be going back in. I plan on just installing one of my B20A's, which will get cleaned up and maybe get some new gaskets, but I'm not planning on any serious bling on the engine this first time around. but we'll see what happens, maybe I change my mind.
  9. #84
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Quote Originally Posted by thegreatdane View Post
    Did you weld yours?
    Yup, and not least while You weld, metal have tendency to wobble as well. Ouh, You mentioned it. LoL...
    No i didn't weld mine thats why I will redo those, I just used FiberGlass Filler. Its strong substance, but if anything happen's at the maul for instance, someone bump in to me, it will crack. So now I'm looking for a garage and a parts car... But its least of my problems, I just noticed that cancer spread on passenger side, under rear wheel arch, so I need to do this as well.
    I have a request for You. If you can find part number for me on that black box, that goes behind digidash, I'll might find, by part,nr. in Japan. Can you do it for me?
    Thanks
    My Build Thread
  10. #85
    Jan 2003
    Denmark/Europe
    Thanks
    I can look it up for you when I get time to intall my JDM EPC, but I very much doubt you can get it new from honda. I've requested other parts of that setup from honda, and nothing was available.
    If anyone reeaaly wants a digi dash I suggest looking into an s2k cluster instead. they are much more simple. I helped out a friend install one in his '91 civic and that was a breeze, compared to my own digi dash.
  11. #86
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    I was in to that idea actually ) but wiring is my worst nightmare I need someone to guide me there. But I dont give up. It might just happened... Thanks m8
    My Build Thread
  12. #87
    Jan 2003
    Denmark/Europe
    New goodridge brakelines with stainless fittings and TUV approval. One kit for each accord. paid £173 GBP ( ~$350 US) for everything. Seems like a very nice kit.
  13. #88
    Jan 2003
    Denmark/Europe
    Can You figure out how it works?
    OMG!! where's it's face??!! OMG
    Screw it, I'm replacing the entire rad support I decided. I didnt like all the rust spots it had everywhere. Here's the new one, which isnt from Honda so it wasnt so expencive.
  14. #89
    epic1400cs's Avatar
    Jun 2004
    1989 CA5 Aerodeck EXi 2.0 A20A4
    London, UK
    but
  15. #90
    hope the rad support fits right!
    Jan 2003
    Denmark/Europe
    It does. Better than I had thought actually. Not perfect of course but close.
  17. #92
    man you are build a 3gee all over again.
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    So what is it from? I was looking at mine a while ago, and was a bit disappointed.
    My Build Thread
  19. #94
    Jan 2003
    Denmark/Europe
    It's from a company here in Denmark called NOR : http://www.nor-as.dk/
    I think you have "Mekonomen" in Norway, right? They sell the parts from NOR.
  20. #95
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    This is correct, this is where my rockers/channels came from. only drawback is that they are not precut/fab. need to adjust, and cut where needed. How much did you spend on that front end?
    My Build Thread
  21. #96
    Jan 2003
    Denmark/Europe
    I payed 2000 DKK but that was with a 31% discount.
  22. #97
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    looking good man keep it up.
  23. #98
    that fuse box relocation is amazing, the front of the car looks nice too
  24. #99
    Jan 2003
    Denmark/Europe
    lol. The fusebox relocation is finished I just need to add the battery cables and wrap all the wires back up. I like where I placed the fusebox, since theres still room for the glovecompartment and the black plastic cover that sits above your feet to cover up the blower and the heater duct.
    I made the glovecompartment so that it functions normally and when I need to acces the fusebox I just pull up the tab on each side of the glovebox, and then it opens up enough to allow access to the fusebox -as illustrated on the pics. And the glovebox light will provide the lighting needed to see what your doing when you need to replace a fuse. It's as if the fusebox was meant to sit there I cant access the lower main fuses though but I think I'll be alright.
  25. #100
    coolio
    edit: w0oOo0t i got post 100 in this thread
  1. Fedor's Aerodeck Audio Project
    By Fedor B. in forum Interior & Exterior Care
    Last Post: 04-13-2012, 10:22 AM
  2. thegreatdanes Aerodeck restoration project
    By thegreatdane in forum Interior & Exterior Care
    Last Post: 03-29-2010, 10:08 AM
  3. thegreatdanes B20A dyno tuned, dynosheet
    Last Post: 05-23-2007, 03:47 PM
  4. thegreatdanes bunch of new 2.0i-16 pics
    Last Post: 03-13-2007, 08:08 AM
  5. Deckki's Accord Aerodeck project
    By Deckki in forum Classic Honda Pics & Videos
    Last Post: 09-11-2006, 11:05 AM
