Results 1 to 12 of 12
Thread: Ignition problems?
    LX User Estimated Prophet's Avatar
    Mar 2007
    88 LX-i Hatch MT
    Atlanta, Ga
    Ignition problems?
    My car ran fine on the way to work this morning and during my lunch break but not when I went to leave. It would crank and cut off instantly. This repeated 3-4 times and then would crank and run fine. If I shut it off it will crank right back up fine after this. But if it sits and cools down the process repeats.
    Honda Parts Connection -- http://www.acurahondaparts.com
    D Series Army Dishonorable Discharge
    BT Defector
    DX User dlr1989's Avatar
    Mar 2007
    Originial Owner of a 1989 Accord LXI 4 Dr
    Hastings, Nebraska
    Re: Ignition problems?
    Does the car die the instant that you release the key after the engine starts? Are things like the clock and idiot lights on or off after it dies? What you have described sounds a lot like an ignition switch problem. 3rd gen accords are notorious about this.
    They can have my Accord when they pry the steering wheel from my cold dead fingers.
    77 accord hatch 79 - 85
    82 accord LX hatch 85 - 87
    89 accord LXI sedan 89 - 09
    09 accord EX-L V6 w/Navi sedan 08 -
    My garage
    Quote Originally Posted by dlr1989
    yup it happen to me a month ago at like 2am play with the key and try to hold it in place or just wiggle it.
    Mar 2007
    88 LX-i Hatch MT
    Atlanta, Ga
    Yeah definitely the the ignition switch. If I hold to a certain spot like Messy said it will stay running. Gotta wait till Monday to replace it. I was supposed to go get laid tonight but the 3g is cock blocking me.
    BT Defector
    dont you just love it when a plan cums thru...
    "A team"
    count yourself lucky though at least it was not the headlights going kaput in the middle of the night, from the ign switch failing.
    Mar 2007
    88 LX-i Hatch MT
    Atlanta, Ga
    I wish I had a camera, I rigged a screw and a wing nut that wedges between the column and the key to keep it running. I McGuyvered that shit so I can drive it until Monday.
    BT Defector
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Quote Originally Posted by roodoo2
    The headlights aren't wired through the ignition switch, but the turn signals are.
    CARDONE SUCKS.
    Quote Originally Posted by LX-incredible
    True, then ok how about the alternator field.. lol
    anyway advice for all, one thing that can get this type of thing started is having a couple pounds of keys ( or a bunch too many ) on your key ring.
    Quote Originally Posted by Estimated Prophet
    yup....i got mine new from honda...it was like 55 bucks....only took like 20 mins to install. i would unplug the batt because i blew a fuse since the back of the switch is bare and i think it touched ground.
    Vanilla Sky's Avatar
    1999 Penalty Box
    I thought you knew better than to prepay for teh sexors!
    While this has been reliably diagnosed as an ignition switch problem, I had a similar problem that turned out to be fuel cutoff relay related (carbed car). Replaced the relay with a spare and fixed the problem.
    Mar 2007
    Hastings, Nebraska
    Definitely pull off a battery connection when relpacing the ignition switch. I dropped a socket that hit the back of the switch and blew a fuse when I installed mine. None of the local autoparts places had the exact fuse on hand, so I had to special order it.
    My garage
    yeah... i went to kragen, napa and they didnt have it so i went to honda and they didnt have it i told the guy that i needed it the same day so he checked the computer and found one in the honda like 15 mins away.....i drove down there and he said they had like 8 left.....cost me like 8 bucks also.
  1. ignition/radio cut off problems
    By 88accordlxcarb in forum 3geez Accords
    Last Post: 05-27-2009, 01:56 AM
  2. MSD Ignition Digital 6 Plus Ignition Control
    By 86hondadx in forum Restoration & Custom Fabrication
    Last Post: 09-19-2006, 09:13 AM
  3. idling problems, starting problems...
    By AccordDX86 in forum 3geez Accords
    Last Post: 10-13-2005, 10:17 AM
  4. Replies: 15
    Last Post: 07-11-2005, 04:45 PM
  5. Ignition and idle problems?
    By BaTmAnLintz in forum Classic Honda Community Chat
    Last Post: 08-16-2004, 05:11 PM
