Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 84
Thread: Re: PROJECT: Full bodied coil overs
  1. #51
    15kg/mm Front : 18 kg/mm Rear, the car rides great, but it takes some getting use to. I personally like the feel of very stiff suspension, but that is definitely not for everybody.
    I get those numbers as 825 front 925 lbs/inch in a rough conversion. Damn and you guys thought I was crazy with 600/400.
    I think this is great work.
    Is there any chance that a more stock ride height can be achieved or something close to it ?
  2. #52
    Not crazy, just devoted . You could definitely get something close to stock. Options can be choosen from an array of spring rates. (3.5, 5, 7, 9, 11, 13, 15, 18, and 22 kg/mm) and you can choose back and front separately.
  3. #53
    wprocomp's Avatar
    Armrest whore
    I have 9kf/12kr,and it shows!
  4. #54
    so can we use any 4th gen rear shocks or do they have to be part of a coil over kit? or do just just have to have adjustable spring perches? cause then we could use koni yellows for 4th gens
  5. #55
    Well, you would not be able to use any 3gee springs, because the 4th gen springs are much smaller in diameter. I dont know if the strut would be to short as well. Honestly that would need to be tested.
  6. #56
    ok cool thanks
  7. #57
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Well antares are you happy? i get konis so you have to make me look like a deuche. lmao way to go man your a true pioneer. So are you finally set or is there something in the future for you?
    '89 SE-i Coupe
    Awaiting Garage
  8. #58
    You know it's my duty as a Texan to make you oklahomans look bad . I need to build a better motor, finish the rear brakes, and turbo. Then I need to paint and get some seats to finish this car .
  9. #59
    Whats the update on this? Good bad ugly ?
  10. #60
    Good: handles beautifully
    Bad: Rides really ruff
  11. #61
    Shameless post pad here
    I meant to ask can the ride height get close to stock ? Or how low do you think it is currently?
    Thanks gald its working out sounds like something I might be after.
  12. #62
    Feb 2007
    88 DX Hatchie
    even just city driving is bad legend? on the softest setting?
    "The Original White" 88 DX Hatchback
    Mysterious Project Car
    www.myspace.com/tunerplayground
    You won't know what hit you
  13. #63
    Well just a comparision
    CC248
    Front TRW spring replacement 278.5 lbs/in
    CC221
    Rear TRW replacement SPRING RATE= 170 Lbs./In
  14. #64
    The suspension could definitly be raised back to stock, and still maintain the pre-load. I think I went with a little to stiff on the rear for a daily driver though. I have gotten the wheels close to coming off the ground while moving a couple times now, and It definitly handle very well in a track like situation. I really need to get a better daily driver .
  15. #65
    Maybe I did it wrong I wanted to just duplicate the threads but just moved a few posts around to make a how-to thread in the how-to forum and leave the rest of the posts here.
  16. #66
    Looks good to me .
  17. #67
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    That's where helper springs come into play-- more articulation, basically.
    As for stiffness, yeah, you def went overkill, though I'm not entirely sure what the wheel rate is for the Honda (since 18k isn't a true 18k, more like 14k, which is still way too stiff, esp. for d2 dampers).
    Alex
  18. #68
    Quote Originally Posted by 86AccordLxi
    Alex
    Well the dampers work great with the spring rate, it's jsut my ass and back that dont work so well with the setup . I really like the stiff ride, but for a street application I would go down one set of spring rates.
  19. #69
    LX User P|eszczoH's Avatar
    Nov 2003
    2 x 1989 Honda Accord Aerodeck 2,0i Exclusive Edition(lather, and one with A/C)
    Warsaw, Poland, Europe
    Legend_Master, You really are a Master :-)
    The car is great, Your invention is more than I could ever expect...
    You don't only think like most of us, You just do the Job.
    Engine swap, brakes, susp ... I mean whole susp. not only coilovers...
    what is next ?
    I love Your ride, it is road car , and can be daily driver even with those mods.
    have a nice ride
    P|eszczoH
  20. #70
    Quote Originally Posted by P|eszczoH
    what is next ?
    Thanks P|eszczoH, after owning a 1st gen Legend I am happy to have a car with interchangeable parts from other cars. As for my next project, I have a turbo kit and I am working on all the necessary fuel parts to make it work.
  21. #71
    2drSE-i's Avatar
    Oklahoma City
    antares...you turbo that beast and i can almost guaruntee you accord of the year.
    '89 SE-i Coupe
    Awaiting Garage
  22. #72
    It's going to be awile, I need alot of shit to get this going.
  23. #73
    You know you can buy full coilover kits from Hot Bits? And they start from $800 upwards depending on what options you want.
  24. #74
    Quote Originally Posted by rjudgey
    I have never actually seen anybody running those, and I am not to familiar with the company in general. How is there quality?
  25. #75
    http://www.hotbits.org/v3/product.cfm
    and if im coorect it says something like $2800 for the adj kit
  1. full bodied coil overs vs coil over sleeves
    By newaccorddriver in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-19-2007, 11:54 AM
  2. full bodied coil overs vs coil over sleeves
    Last Post: 06-17-2007, 11:57 PM
  3. [Suspension, Wheels, Tires & Brakes] PROJECT: Full bodied coil overs
    By Legend_master in forum How To
    Last Post: 04-20-2007, 07:28 AM
  4. Full Coil-overs. Why not?!?!
    By w00tw00t111 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-29-2005, 09:21 AM
  5. Full Bodied Coil-Overs
    By markmdz89hatch in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-16-2003, 09:49 AM
