Page 4 of 4 FirstFirst 1234
Results 76 to 92 of 92
Thread: Fuel Pump Help
  1. #76
    Re: Fuel Pump Help
    Quote Originally Posted by buttaz1
    i only have one pump
    one is the float and one is apump
    one has the bolts and the other one has the clips?
    the one on the drivers side is the pump. it will have the connector with two wires to it.
  2. #77
    Sep 2006
    Re: Fuel Pump Help
    so why is the intank fuel pump bad?
  3. #78
    Re: Fuel Pump Help
    because they aren't using it I mean why would they add a second pump if the one in the fuel tank worked?
  4. #79
    Re: Fuel Pump Help
    well for one thing,unless you go to the dealer,about every replacment one out there is dog shit. you don't want to know how many pumps i went through. it might be fine also on a bone stock engine,but any mods and it's gasping for breath. i've had a fuel pressure gauge for years,and everytime you step on the gas the pressure goes to zero. it's pathetic little trickle of fuel probably couldn't keep up with a flipped lid mod,let alone anything serious. i'm going to be running dual sidedraft carbs here shortly,it def won't be able to keep up. it also is prone to burning out with anything less then half a tank,i haven't tried the bosch pump myself yet,but to be fair i've heard it's good. still stock specs though. i have searched and searched,and there is simply no one who makes an upgraded in tank carb pump. only efi pumps. this pump i found will meet my specs perfectly and will be able to keep up with almost anything.
  5. #80
    Re: Fuel Pump Help
    oh thats what he ment by bad I thought he was asking why his was bad
  6. #81
    Sep 2006
    Re: Fuel Pump Help
    yea
    i hope this will help me out i really really really need a car im so desprite im thinking of getting a hyundai
  7. #82
    Re: Fuel Pump Help
    if you end up with a bad carb,go to importcarbs.com they have the best prices of anybody. all their carbs are overhauled and tested. they have been in buisness for a long time,so that says a lot,also the guy who owns the company rebuilds every carb personally. if i was buying another factory one,i def would get one from them.
  8. #83
    Sep 2006
    Re: Fuel Pump Help
    ok so
    i just got paid and its great so now i am wondering to take out the fuel pump do
    i have to drop the tank? i doubt it but do i need to?
  9. #84
    Re: Fuel Pump Help
    There should be an access cover in the trunk area over the tank, you remove the plate and there it is.
  10. #85
    Re: Fuel Pump Help
    I m not sure really if the pump is your whole problem. Most times the carb is the culprit on these cars when they get old.
    The timing turned up with the distributor the idle will go higher. You really should use a light. You should be getting 20 mpg at least with that car. Most get alot higher but that is a good place to start.
    I assume you used NGK spark plugs and the correct part number ?
    You may want to pull one and see what the tip looks like as well that tells you how the cars is running.
  11. #86
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: Fuel Pump Help
    There is a volume check on the fuel pump you can do. I don't have the specs at this point in time, but being it's at 3-6 psi. I assume if you take the line off going to the carb & put it in a milk jug. If it fills it up 3/4 to full in 1 minute, it's fine.
  12. #87
    Sep 2006
    Re: Fuel Pump Help
    ight its 912 now im going to start the switch
    hopefully i can do this before 10 am i gatta be at work
  13. #88
    Sep 2006
    Re: Fuel Pump Help
    ok i changed it took
    ME about 20 30 mins and the car ran like shit at first then it settled out then it ran perfect it idled great it sounded a lil flawed though and then the car started idleing weird up and down and up and down and up and down it was really bad then i started noticing some smoke and then the fans didnt start up so now im thinking i have a pressure problem coolent pressure?
    or the carb. im not sure which yet ill check it later i have to get tto work
    thanks guys
  14. #89
    Sep 2006
    Re: Fuel Pump Help
    alrighty then
    i think tommerow morning before i go to work im going to go get the carb out the car and take it apart and clean it out make sure everything is clean then ill mess witht hte a/f ratio maybe thats a problem lets see
    oh and i bought the hanz manual im reading right now
  15. #90
    Sep 2006
    Re: Fuel Pump Help
    ok i think i fixed it
    there is no erectic idleing and all the only problem i have is that there is like
    a noise with the idle
    like ok it goes vom pop(faintly) its something that you have to pay attention to the exhust sound to notice. do you think i should worry about this?
  16. #91
    Re: Fuel Pump Help
    Timing is off.
  17. #92
    Sep 2006
    Re: Fuel Pump Help
    ok
    so ill have to make a stop at the mech
    but i drove it to the gas station and it drove well only thing is that it was a lil hasitent.
    or maybe its cuz i was nervous that it would leave my ass
    but tommerow i am off so ill work on it
  1. Fuel Assembly , Pump , & Fuel System Location
    Last Post: 05-10-2016, 01:27 AM
  2. fuel pump
    By tyler_hiya in forum 3geez Accords
    Last Post: 03-07-2011, 11:53 AM
  3. Fuel Filter? Fuel pump?
    By Bass Man in forum 3geez Accords
    Last Post: 05-19-2008, 03:38 AM
  4. Replies: 2
    Last Post: 12-15-2006, 07:25 AM
  5. Fuel pump?
    By blok2400 in forum 3geez Accords
    Last Post: 09-30-2003, 12:54 PM
